Rotel rsx-1067 not staying on? whats wrong and what to replace with if needed.?
Polkie918
Polkie918 Posts: 245
edited November 2009 in Electronics
My bro has a 7.1 home theater room and his receiver is acting up its a rotel rsx1067.....he says as soon as he turns it on it "clicks" right off and if he unplugs it from the wall and then turns it on it will stay on for about 45 seconds and click off and then will instantly turn off if u try again..
any idea what the problem is?
what can he get to replace it...I was telling him about my onkyo 806 and he likes it but I dont know if that will compare to tthis high end rotel.....
any info would be great thanks
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Post edited by Polkie918 on
  • Polkie918
    no one knows?
    Fronts- RTi8
    Center- CSi5
    Rears- FXiA4
    Sub- Velodyne 12"
    Onkyo TX-SR806
    Ps3
    Xbox 360
  • Sherardp
    Sherardp Posts: 8,038
    I'm not a Rotel guy, but have him check the power cable and insure its fully seated. I would also suggest he check speaker cables and the like and make sure nothing is touching or causing a short across terminals. That would be a good place to start. I think Mantis is a Rotel guy, some others may chime in also.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Check all connection's as already suggested. If the problem still persist's it may be a PSU/transformer issue?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Polkie918
    he unplugged everything and tried just having it stay on with NOTHING connected...it would stay on for a bit then shut off and then shut off right away if tried to turn back on...
    he is gonna sell it as broken and get something else...im sure he can still get a decent amount of money for it...i was thinking at least $300 and someone can fix it.
    Fronts- RTi8
    Center- CSi5
    Rears- FXiA4
    Sub- Velodyne 12"
    Onkyo TX-SR806
    Ps3
    Xbox 360
