Parasound HCA1500A - 19" Rack Mount
dorokusai
I just purchased another Parasound HCA1500A, from the same guy, he has another available. $550/obo + shipping. It is a John Curl design, amplifier pioneer, and designer of Mobile Fidelity Sound Labs(MFSL) recording facility(Original). I wasn't sure if any of you are interested but here are some specs from the website:
Circuitry designed by John Curl
THX Ultra-certified
Direct Coupled - no capacitors or inductors in signal path
Hand matched complementary JFET input stage and MOSFET driver stage
16 beta-matched 15 amp, 60 MHz bipolar output transistors
1.0 kVA Toroid power transformer with independent secondary windings for each channel, 60,000 µF power supply filter capacitance
Independent power supplies for each channel
DC Servo and relay protection circuits
High bias Class A/AB operation
AC present, standby/normal, current overload indicators
Tiffany-style RCA input jacks, loop output jacks
12 volt DC automatic turn-on circuitry
Gold-plated 5 way speaker binding posts
Custom designed removable IEC AC cord
Rear mounted gain controls; ground lift switch
3 rack space height front panel
Rack mounting adapter available
Continuous Power Output - Stereo: 205 watts RMS x 2, 20 Hz - 20 kHz, 8 ohms, both channels driven; 315 watts RMS x 2, 20 Hz - 20 kHz, 4 ohms , both channels driven
Continuous Power Output - Mono: 630 watts RMS, 20Hz - 20kHz, 8 ohms
Current Capacity: 60 amperes peak per channel
Slew Rate: > 130 V/µsecond
Power Bandwith: 5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion: < 0.03% at full power; < 0.01% at typical levels
IM Distortion: < 0.03%
TIM: unmeasureable
Dynamic Headroom: > 1.5 dB
lnterchannel Crosstalk: > 80 dB at 1 kHz; > 60 dB at 20 kHz
Input Sensitivity: 1 V for 28.28 V, THX Reference Level; 1.4 V for full output
Input Impedance: 33 k ohms
S/N Ratio: > 118 dB, full power; 96 dB, THX Reference Level
Damping Factor: > 800 at 20 Hz
Power Consumption: 800 watts
Dimensions: w 17 1/4" x h 5 1/4" x d 16", h 5 7/8" with feet
Net Weight: 40 lb.
It is a really great amplifier. We demo'd my first one on F1's SDA's and it had a noticeable increase in bass, clear mids, clear highs. I have read comments that the amp is heavy in the bass area, one commented that it was a little "dark", but I have no idea what he meant. The amp was more than ready to keep on going, it has some very large guts. We just did normal listening... F1 had more time with it than I did. He may offer some comments.
We are planning on using both of them, bridged to 630wpc, on his SDA's this Friday or weekend...unsure, but it looks to be pretty cool experience.
Drop me a line if you have any seller or Parasound questions.
Thanks for looking.
d
THX Ultra-certified
TIM: unmeasureable
Net Weight: 40 lb.
Thanks for looking.
d
Sorry, here is the link:
http://cgi.audiogon.com/cgi-bin/cl.pl?ampstran&1069103751
Yes I know how to edit, I am lazy :mad:CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
WTF, I swear I am retarded....how do you attach. I have used all these options.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
