Denon DRA-37 Stereo Receiver thoughts ???
buymesome
Hi guy just wanted to know if this might sound ok with a pair of rtia5 (if i ever get em back) in a very small room
If I got LSI 7's would it rock them? I think you can add an amp to it also
It may be my first reward for quiting smoking
http://www.amazon.com/gp/product/B000HFWXOE/ref=olp_product_details/185-2227812-8725504?ie=UTF8&me=&seller=
Nearly forgot to ask , will this be a big improvement over stereo mode on my 607?
Post edited by buymesome on
For LSi7's, no. Get an external amp for 4ohm loads.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
This does 4 ohm loads fred
Can't imagine how well it'll play or how loud you can actually get it at. If you're going to listen to it at reasonable levels in a small room sure why not.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Here the link
http://www.usa.denon.com/ProductDetails/AMFMStereoReceivers.asp
On the page it says its 4ohms stable . Is that the same as 4ohms ? does then mean the 50wpc @8ohms then doubles to 100wpc @4 ohms ? -
Here the link
That's just the thing, it's 'stable'.
I personally wouldn't run it, given the volumes I listen to music at. I also doubt that receiver will be able to supply the current LSi's demand under heavy load, remember it's not all about "wattage".Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
I had one for a while. It is a very sweet sounding little receiver. Think I paid like $60 for mine when Circuit City went out of business.
I'd be a little more apt to pick something like this up, than that...
http://www.polkaudio.com/forums/showthread.php?t=86901
But, i'm a little biased, admittedly.
But why don't you just piece together an entry level separates setup? Preamp of your choice coupled with an Adcom GFA-535 or something.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
