SVS PB12-Ultra/2 Subwoofer - Signed
dorokusai
SVS PB12-Ultra/2 Subwoofer - Piano Gloss - 9/10 - *SOLD* to Bluemdpicker
Until the PB13-Ultra, this was the bar standard in hardcore subwoofers. I'm downsizing but this subwoofer was always WAY too much for my home theater. This is the baddest subwoofer I've heard to date. The piano gloss finish is stunning and it's always been a conversation starter since I bought it.
I had it signed prior to shipment in 2005 by SVS elite....Erik Kroner(Design Engineer/CS), Ron Stimpson(Co-Owner) and Tom Vodhanel(Co-Owner/Subwoofer Legend).
*UPDATE* I talked directly with Ron from SVS since I'm going to buy a PC13 Ultra and he still feels this is the best subwoofer they've made. I recently bought the SVS AS-EQ1 per his suggestion and it dramatically changed the performance of this subwoofer BUT I really need some space so I can fit some larger speakers in my HT. I don't want to sell it but in order to change things sometimes you have to sell things. I highly recommend the AS-EQ1, it's awesome.
The subwoofer was $2400/shipped in 2005.
Specifications:
Twin TV-12 "Ultra" woofers SVS's best
1,000 watt BASH (R) amp with built-in PEQ
Flush-mount amp configuration
Computer Assisted Design (CAD) enclosure
Down-firing configuration
Distinctive SVS integrated base-plate
Compliant floor mounts, low center of gravity
Three 4" high-flow flared porting (in and out)
Built and tested by SVS in its Ohio factory.
Extra heavy-duty detachable 8 foot power cord
Finished in four veneers, gloss or textured black
Selectable 16Hz, 20Hz or 25Hz extension
+/- 2 dB 18 Hz-200 Hz anechoic in 20hz mode**
Size: Approx. 19" wide, 26.5" tall and 28" deep
Weight: 190 pounds
Woofer Specifications:
Cast aluminum frame
Under-hung motor, voice coil stays in gap during max power
97oz strontium ferrite magnets
Vented pole piece
High tension binding posts
Rigid Kevlar and aluminum cone
Inverted dust cap
Dual progressive Nomex spiders with sewn-in tinsel leads
Integral rubber mounting gasket
1" Santoprene surround capable of over 2" peak to peak excursion
Ultra high capacity 3" aluminum voice coil, with Kapton former
Copper shorting sleeve eliminates gap induction and reduces flux modulation distortion
Secrets Review - 2004
Includes: Original everything and packaging.
0011P2U21BPSVS
Specifications:
Weight: 190 pounds
Cast aluminum frame
Vented pole piece
Inverted dust cap
0011P2U21BPSVS
Post edited by dorokusai on
I'm sure it won't come to this, but I'm interested when you are willing to ship this beast across the country.
damn mark. that shi* is the shi*. bump for ya.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
190 lbs.. dang.. that's a heavy weight.PolkFest 2012, who's going>?
Nice...
how much to ship to Northern VA. 20152?
thanks -
I have seen, heard and FELT this thing is person. It pressurizes a room and you feel this thing in your chest. I can echo the statement that this is the baddest sub I have ever seen. It's worth a road trip for anyone interested.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Nice...
thanks
I'll deliver to NVA.
Thanks guys!!
CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I have PB12/Plus 2 in a dual configuration. This sub being sold was the big boy to mine so I know it will definitely slam almost any room. Nice sub mark, GL with sale.Shoot the jumper.....................BALLIN.............!!!!!
Thanks guys!!
In your post, you didn't indicate where you're located.
How is this compares to the PB13 Ultra? My friend recently bought the PB13 Ultra for $1600 shipped but haven't heard the PB12. -
Damascus, MD.
The PB13 hits lower....otherwise its almost identical if not better thru 20hz but that's when the PB13 kicks into overdrive. The PB13 in piano gloss black is $1800/shipped.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
What's the pick up location? ZIP?
Damascus, MD 20872
That beast rattled my insides! GL with the sale Mark.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Anyone?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I drove 3 hrs one way and paid $1000 for my Plus/2 over 3 years ago and it's still the best investment I've ever made in my system. And mine's not even piano black.
If you're within 300-400 miles of this and need a sub...GET IT!!! You WILL NOT be disappointed.Things work out best for those who make the best of the way things work out.-John Wooden -
How big of a difference is the Plus/2 over the nsd/2?Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
It's an Ultra/2 not a Plus/2...and it digs deeper and stronger. That's two(2) TV12....check out the links.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Mark, I think you need to drive towards Chicago so I can take this sub off your hands!!!!Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables -
LOL...if my father still lived there, we could've worked something out
Just wanted to mention it cost me roughly $150 to ship my plus/2 from Milwaukee to Dallas. It has the same size cab as the Ultra but weighs 50 less.
Mark do you still have the packaging? -
Yes, but I'm not even trying to ship this thing. I already have back issues lol.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I sent you a message. Thanks. -
Replied.
Subwoofer is still for sale.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Last call before I just put it back into position, to crush my newly decorated HT room.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Someone should get this, what a deal for a sub that will put you in the "Full Nelson".Shoot the jumper.....................BALLIN.............!!!!!
Local? Free delivery withing a couple hundred miles? I'd really like to get a SVS tube in the corner.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
oh babey that would be a helluva christmas present
drool droolSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
I can sign it for you also Sandworms....I'm more infamous than famous tho'....
that thing is a BEAST !!
too bad I wasn`t closer, I could trade ya my PC-Ultra !!
Somebody jump on this babyCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
That would be perfect Robert!
I need to move to MD !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Hello there, I am new to the forum. Stumbled across it looking for a SVS ultra...I am in NE Ohio...just under a six hour drive from you. Would you be willing to travel some? if so how far. Thanks for your time.
