What's next....hmm
kawizx9r
kawizx9r Posts: 5,150
edited November 2009 in DIY, Mods & Tweaks
So, I'm not just satisfied with my setup.....I'm really happy about how it's come out! Tubes burned in, cables burned in, amp is fully modded, placement to me sounds right given the room size/shape, everything works so well together!
I've decided to put off the 'huge step up to a more respectable tubed preamp' and want to focus on anything else I can do to my setup.
That leaves a few things left which are possibly; room treatments (difficult to do in my situation, but will try), upgrading my power cords (no extra funds atm for audio), modify my source?
I've read about DIY mods for the 29xx and 39xx denon dvd players but has anyone modded a dvd2800? I can work my way around soldering electronics (got plenty of exp), and it'd be cheaper than buying a DAC but what would I do to it exactly?
Any help is appreciated! Just looking for something to do over the next couple of weeks.
-Freddy
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
heiney9 wrote: »
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
  • steveinaz
    steveinaz Posts: 19,545
    Personally, I'd start with a dedicated CDP. Rotel, Cambridge, Music Hall....
  • me_myself_I
    me_myself_I Posts: 15
    The Music Angel components are typically run of the mill stuff. Not really state of the art. I would think some modifications could improve them. A great amount of the amplifiers and preamps imported from China are based on vintage circuit designs.
    When I mean modding I don't mean rolling tubes or changing caps and the like, but altering the circuit topology by adding constant current sources or properly regulating the power supply. How handy are you with a soldering iron? And do you have a schematic we can look at?
  • concealer404
    concealer404 Posts: 7,440
    Huh?
    mhardy6647 Posts: 35,029
    Build yourself some 'audiophile' power cords with parts from a boutique if you like, or a semi-boutique like Parts Connexion or a non-boutique like PartsExpress! :-)
    The two vendors I named are both fine to do business with in my experience and NSHO.
    http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=912&CFID=5980163&CFTOKEN=40573219
    http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=914&CFID=5980163&CFTOKEN=40573219
    http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=478&CFID=5980163&CFTOKEN=40573219
  • Systems
    Systems Posts: 14,873
    I think he's looking at modding his Denon not his pre.
    The D-A section of your unit should be very capable as I believe it incorporates a custom version of Burr Browns's excellent PCM1792 dual differential dac chip. IMO with units like your Denon the biggest performance gains are usually obtained by upgrading the analog section,ie. installing better opamps for the current -voltage convertor and low pass filter /output buffer section,removing or upgrading output coupling caps and improving the power supply regulation.
    Testing
    Testing
    Testing
  • Systems
    GV#27 wrote: »
    Correction it's the 2900 that uses that DAC,not sure which one is used in the 2800.I did a quick search for a schematic so as to give some specific suggestions but have'nt found one yet.
    Testing
    Testing
    Testing
  • kawizx9r
    Oh man, I didn't think anyone had even looked at this thread. Where to start?
    steveinaz wrote: »
    I've looked at that, but I was looking torwards something a bit more budget-friendly if it's to happen in the near future.
    I'm really handy with a soldering iron/schematics. I just couldn't find many mods that provide an accurate description of what was done. The M.A. is based off the Marantz model 7A preamp iirc. I've seen several modded M.A.'s and they sell for a good +1,200! A sick preamp to mod, but in it's stock form it gets by being a beginner's tubed pre.
    Huh?
    Just blame Curt :p
    That's actually what I've had in mind. I didn't look at your links just yet, but I've been checking out P.E. for parts I might use.
    GV#27 wrote: »
    Yea, I've seen alot of mods on the DIYforum for the 2900 and several other places but I've got a 2800. If I see a 2900 around here I'll consider it, think there was one on CL for only 80 bucks but I was looking for Maggies at the time :o
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
