2) micro1000s w/ 1) LFE output
Did you get this confirmed directly from Polk? If so, it'll be a race to order from Parts Express...1/4 - 20
Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!! -
they fit, though a little "loose". Firms up when you screw them all the way in.
However, I did not like the way they worked. I have the subs sitting on 12"x12" concrete paving blocks with 2 block on top of them. They still jumped too much. They are much better in my set up with the standard rubber feet.custom HTPC, Maya44 USB DAC, Dared SL-2000A, VTA Dynaco ST-70, Tekton Design OB4.5's and Polk DSW microPRO 2000's -
Sorry to hear this. These were the P/E spikes, correct?they fit, though a little "loose". Firms up when you screw them all the way in.Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!! -
Yes, the Parts Express spikes. They are fine if you screw them in all the way. I don't think they'd work well if you need to level-adjust.custom HTPC, Maya44 USB DAC, Dared SL-2000A, VTA Dynaco ST-70, Tekton Design OB4.5's and Polk DSW microPRO 2000's
You could always add a nut to the spikes or us the screwed on washer that come on the original feet. That way you'll be able to adjust it.
