5.1 Home theater - OWM vs RM95 pack ?
Hi guys,
Just wondering if any of y'all have had a chance to compare the two and would love to hear your thoughts:
IN THE BLUE CORNER:
- Fronts L/R - Owm3
- Center - Owm5
- Surrounds - Owm3
IN THE RED CORNER:
- RM95 (or RM85) -5-pack system
(To be placed in a relatively small room and all speakers to be mounted on the walls. To be used mostly for movies)
Sub will be PSW110
IN THE BLUE CORNER:
- Fronts L/R - Owm3
- Center - Owm5
- Surrounds - Owm3
IN THE RED CORNER:
Sub will be PSW110
Post edited by Topper on
nobody's had a chance to play with them both?
I have the 95 pack and it did about as good of a job as you could expect from such small speakers. Actually much better then I expected, but they are now my side and rear channel speakers after upgrading. If I were you I would look for some larger bookshelves on polks ebay store. You could get much better bang for the buck there then by buying the rm95's new.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
I haven't tried the OWM, but I have some on the way:D I'm with bevo, I have the RM85, and it does very well considering the size. However, speakers are in some respect like cars. There's no replacement for displacement:DSony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
yep i completely agree with y'all but in this particular application, i really need a small speaker system to be mounted on the wall and it looks like only the OWM and RM series fit the bill.
(I already have RTi A series gear in my main theater area and my bro has a full TSi setup in his place. This is for our bedroom and the wife is only agreeing if its between these two
I know the RM85/95 sounds great for it's size, it's a shame you're not local,lol! I'm trying sell a set of RMs I just purchased that I don't like for my particular application. From what I can tell the OWM would most likely have a fuller sound and blend easier with a sub given the larger mid/enclosure and lower response. They seem like they would give a lot of mounting flexibility as well. The RM can also be wall mounted, just with a little less flexibility I suppose. After all is said and done, the OWM or the RM could be had for around the same price from Polk Direct, and both would surely be hard to beat in this price range. I kinda comes down which looks better to you, since both would be just fine for mostly HT duty IMO. Where on the walls were you planning on mounting them? In the corners, by a wall mounted TV?Sony 40" LCD
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
