Working a few upgrades for my HT Room
Sherardp
Sherardp Posts: 8,038
edited November 2009 in The Clubhouse
Decided I was bored with my HT so I decided to work up some minor upgrades. I started today by ordering and installing some designer crown molding at the top of wall/ceiling. Link below for design # 3
http://www.foamcrownmolding.com/id164.htm
My next big task will be doing the star ceiling, but probably just over my seating area. I don't think I need the entire room lit up like that. Stay tuned
Post edited by Sherardp on
  • BIZILL
    BIZILL Posts: 5,432
    pics along the way please.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Sherardp
    Roger that, will work on some pics, once I get things really rolling. Still decided on what type of star kit to go with, or should I go Star laser projector.
  • Systems
    Systems Posts: 14,873
    That is some cool stuff. I saw it in use a while back and was amazed when I found it was basically styrofoam. Looks really good and easy to work with from what I've seen.
    Testing
    Testing
    Testing
    tonyb Posts: 33,072
    Sherardp wrote: »
    No,they make a paint,by day or with the lights on,looks normal,when the lights go off,you have the night sky,complete with meteors if you want.
    Pretty cool stuff,I'll have to dig up a link for you. I know there is a company that comes out to do it and cutomizes the sky for you,planets and such.
    http://nightskymurals.com/ Found one.
  • gelinas
    gelinas Posts: 226
    The crown moulding should be a nice additon, as will a stary ceiling.
    I just checked out your theatre, very nice. I'm sure your dual SVS' pressurize the room nicely.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    187CAM wrote: »
    +1, very cool!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Sherardp
    Did the front screen wall last night and the molding looks awesome. It came in completely white as mentioned and you can paint it any color you choose. I simply matched it with the wood stain of the rest of the molding. Very nice and gives it high end appeal sort of.
  • BIZILL
    BIZILL Posts: 5,432
    hey sherard, post up a pic from further back so we can see the stained molding you're referring to.
    all you guys doing upgrades is ALMOST enough to get me off my duff and do the same. i need to at least paint my HT room. painting is the easy part. pulling the HT away from the walls is the tough part!
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
