spades,bananas, or ? whats your preference?
  • Cogito
    Cogito Posts: 122
    edited November 2009
    Pins on the amp end and spades on the speaker end.
    Hearing is believing.
  • ivansfo
    ivansfo Posts: 145
    cstmar01 wrote: »
    Just curious as to what people on the forum like in terms of connections. I'm currently using bananas but picked up some MIT cables that the ends can be switched out so curious as to if people feel spades are a better connection.
    Count me as one who feels spades provide a better connection. When screwed down at the terminals, the spades provide a very solid connection. I think this connection is better than the typical spring loaded type banana plug where only a fraction of the connector actually makes contact to the terminal.
    So if you don't move around your equipment much, go with spades. But if you are swapping around gear all the time like much of the folks here do, bananas would be more handy.
  • Pycroft
    Pycroft Posts: 1,961
    I use bananas for everything, and have a quick question...do they make different size banana plugs for different gauge wire? I got some think 12 gague wire and the wire doesn't fit well into it at all. Thanks.
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    ivansfo wrote: »
    For some reason i always had issues with my binding "nut's" coming loose after a few day's so that was what really pushed the favour on the side of nanner's :o
    Of all the type of banana plug's i like these style the best, minus the threaded/crimp shoulder/bolster. In the solder only style these rock IMHO!
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • dorokusai
    dorokusai Posts: 25,576
    There's not a human on the planet that could tell the sonic difference between spades or bananas...choose one and move on with your life.
    I prefer bananas because I move alot of loudspeakers thru my home. It's simple plug and play installation.
  • skrol
    skrol Posts: 3,449
    In my comparison of the 3 types of 'naners (Nakamichi labeled), I liked the above pictured "saw" type best because it fit the most snug in my speakers and my receivers. This may depend on your specific binding posts. The down side is that they won't accept as heavy a gauge wire as the other types "standard" and "stick". Of those types I liked the "stick" type the least because they fit rather loose due to the lower spring tension. The "standard" type were good all around.
    http://www.polkaudio.com/forums/showthread.php?t=82272
    When I was using bare copper wire I would loosen and re-tighten once or twice a year to scrub any oxidation away and ensure that they are tight.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Krazyz1
    Krazyz1 Posts: 256
    24kt. gold plated from partsexpress.com. I believe will handle up to 10ga. if using smaller wire , strip it long and fold over till plenty fill in hole then screw the color coded posts wich are stackable if needed. Bodies come in black and red. The only thing so far I've seen they didn't fit ( were half a hole off on spacing ) was on my newly aquired ROTEL RB-1090. DAM it sounds good. I am a CARVER fan at heart , and jerked my 2 M-400's.I listened to 5 different CD's and atleast 2 songs per CD I could hear instruments I didn't hear on the Carvers.So very HAPPY!!!!!!!!!!!!
  • MLZ
    MLZ Posts: 214
    Bananas at the amp, spades at the speakers
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Right now raw wire but thinking with a elite on the way to upgrade to bananas.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • Big Dawg
    Big Dawg Posts: 2,005
    I have both spades and banana to use on my MITs, but I ended up just using the bananas.
  • kawizx9r
    kawizx9r Posts: 5,150
    Stated earlier, naners on all ends minus spades on one end of the maggie mates.
    Just got these locking plugs, and they stay in place much better than the MIT naners and the BJC naners.
    Here's a pic, only gripe is that they're pretty wide.....which brings them a little close together (for my tastes but still pretty spread apart) but nothing to worry about unless we have an earthquake while listening to music lol
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • MANSKITO
    MANSKITO Posts: 295
    edited January 2010
    The best would be which ever connection has the most surface area contact with the binding post.
    Because this would give the most bandwidth for the electrons to travel through and because of this would offer lower
    resistance and more then likely better sound. (although one could argue that uninterrupted unterminated wire would give the lowest resistance.)
    I have not measured but if i had to guess i would say the bananas do.
    A easy way to test this is fill a graduated cylinder with water drop the connector pieces in and which ever displaces the most water will have the most volume, which ever connector piece has more volume will most likely have the most surface area.
    Not exact but its the only way I can think of to get an idea of the surface area of such a complex object.
    But I don't think there will really be that much of a difference between the two in surface area contact with the binding post, you are probably best off buying the connection hard ware that has the highest degree of craftsmanship over which has slightly larger surface area.
    Monitor 60s, CS10 front
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    Pioneer PD-5010 CD player
    Sennheiser HD 650s :D
    Maverick Audio Tube Magic D1 DAC
    AMD Phenom II 940 @ 3.8 prime stabel
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Creative X-fI Titanium Fatal1ty
