Myrtle Wood
NJPOLKER
NJPOLKER Posts: 3,475
edited November 2009 in DIY, Mods & Tweaks
Do any of you guys/gals use or have knowledge of the wooden blocks used to isolate components?
http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1261932778&/Eaglesound-Myrtlewood-Isoblock
Post edited by NJPOLKER on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    NJPOLKER wrote: »
    I went looking for this wood at the local home depot/rona and they don't carry it, said i'd have to go to a lumber yard. I read that it work's extremely well for this aplication :confused:
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • ben62670
    ben62670 Posts: 15,969
    Maple is good too.
    Ben
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Can someone enlighten me here?......:confused::confused:
    I understand the benefits of vibration isolation, but don't understand how a RESONANT hardwood is capable of canceling vibration. I can see it not transferring vibrations at given frequencies that the wood isn't sympathetic to, but that's narrow at best.
  • NJPOLKER
    Sure google myrtle wood The myrtle wood seems to dampen vibration well. I have seen it in small blocks used for feet under components and slabs I believe for under TT's. It can also look real nice too.
    Thats the best I can do on the subject.
  • concealer404
    concealer404 Posts: 7,440
    Huh? Lost me there.
  • John30_30
    John30_30 Posts: 1,024
    I gots plenty of 8/4 maple in 2 x 2 lengths. If I cut those in 1" tall blocks, that will be as good as anything that yoyo can offer cause it's sitting on the grain.
    Don't believe me about shortgrain non-resonance, ask a woodworker.
    You want some for the shipping, shoot me a PM.
  • LessisNevermore
    John30_30 wrote: »
    So they are setting the gear on the end-grain. That doesn't eliminate the resonance, but it greatly lowers the frequency that it resonates at. I've made drums out of the same wood, same batch, one with vertical grain, the other horizontal.
    The horizontal grain shell rings at a much higher pitch, than the vertical, but ring, they do. In fact, I depend on it, and drummers have payed me well for it.
    But this isn't a pissing contest, I'm interested in the physics of why this is to be preferred to a dense, non-resonant material.
  • zingo
    zingo Posts: 11,258
    If you go to any place that sells cooking supplies, you can sometimes find solid hardwood cutting boards, maple or otherwise, that have large rubber feet. Or you could always DIY some similar combination.
  • John30_30
    I'm with you. I'd like to know the science behind it if the myrtle guy is saying his lumber is resonant yet cancels resonance.
    Now I'm curious what parts of your drums you make from endgrain?
  • LessisNevermore
    John30_30 wrote: »
    Stave shells. The drumheads rest on the endgrain, the grain runs vertical. It makes getting perfect bearing edges(the actual place that contacts the skin) tricky, because it likes to tear out. The solution is climb-cutting a very small amount for the finish pass.
  • sTiLlLeArNiNg
    I have heard of people getting butcher block's from like sam's club @ $25 - $35 a pop and having good success :)
    Huh? Lost me there.
    It doesn't take much....
    Media Room 7.1
    HTPC
  • concealer404
    Oh. You're right. By the way, all the advice i gave you when you joined was completely incorrect. Please adjust as necessary.
  • John30_30
    Well, I kinda figured. That seems like the only sensible way to build them. Although the drumhead rests on endgrain, the staves are relying on long grain.
    So although I agree there is some vibrational transference down through endgrain, surely your drums main resonance is from the long grain, no?
  • bikerboy
    bikerboy Posts: 1,235
    Cardas uses that type of wood IIRC. I have made several blocks and find it can help to use the right shape and type of wood. YMMV
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • sTiLlLeArNiNg
    ROTFLMFAO
    All the advice you gave me :confused: I never read anything usefull come off your fingertip's that was directed at me. You must have me confused with someone else because all you fire my way is immature insult's....
    Have another beer :)
    lol
    Media Room 7.1
    HTPC
  • george daniel
    george daniel Posts: 12,096
    FWIW, I had a cabinet shop make me a maple turntable platform upon which to sit my tt.It does a pretty good job of "dampening" , it sounds much more solid and less reasonant when"tapped" now.Can I hear a difference?,, bass seems tighter,and the overall operation of the tt seems much quieter with speakers and headphones.YMMV.
  • concealer404
    ROTFLMFAO
    lol
    I was at work and completely coherent.
    Go back and read your first threads on these forums. I spent time helping you, hell, even defending you to the rest of the people on this forum that you hate oh so much.
  • sTiLlLeArNiNg
    First: I am not a "small" person that "hate's" anybody, i am not like 99% of the people ;) Just because i disagree with someone and they in turn insult me because i present a valid point of view that differ's from their's does not mean i "hate" them. I got better thing's in life to do :cool: lol
    Second: You care to show me where exactly you provided me with all of this help and support? lol
    http://www.polkaudio.com/forums/search.php?searchid=14008053
    Must be some crazy good second hand smoke in your neck of the wood's then? lol :)
    If in fact you did help me in anyway Thank You but i highly doubt you have ever offered any positive comment's to me....
    Media Room 7.1
    HTPC
    Toolfan66 Posts: 18,164
    I think it is time we all stop drinking this guys koolaid and just ignore him. Really it's just not worth the time to respond to his dumbass comments.
    Let him play alone inside his Emotiva box.
