Another help me pick an amp thread
phipiper10
phipiper10 Posts: 961
edited November 2009 in 2 Channel Audio
Looking for my next amp ideally less than $1k.
Here is what I've used to date:
Rotel 990-BX 330W - a bit bright, not the bottom end or full sound I was looking for
Parasound A23 - brief demo - smoother than the Rotel and felt more powerful - was it too much detail.....maybe/maybe not considering an HCA
Blue Circle BC- 22MKII - this was an experience - it was like music soup in my living room, not in a bad way - very physical, enveloping and emotional amp - just too rich for me
B&K Ref 4420 - Pretty close to what I'm looking ..... not to bright or dark....but.....
If the B&K could:
Be bit more detailed
Have slightly better dynamics
Be a bit more forward/accentuated in the mids for the vocals
HAve slightly fuller sound overall
I think I'd be pretty close - so it only has to improve a little in all those areas to get me where I think I want to go! :D
Anyone have this sound in their mind from past experience?
Anyone?
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
  • danz1906
    danz1906 Posts: 5,144
    The Aragon 4004MKII is a good sounding amp with good power.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1262788484&/Aragon-4004-MKII-Sweet!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    nooshinjohn Posts: 25,915
    Sunfire Stereo Grand 300/2
  • concealer404
    concealer404 Posts: 7,440
    In before Emotiva.
  • Systems
    Systems Posts: 14,873
    phipiper10 wrote: »
    If the B&K could:
    Your describing my Bryston 3B;)
    You might take a look at the ST series specifically the 4B if you need/want the extra power vs the 3B.
    Heres one within your budget and still has 10 years of warranty remaining. http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1263260906&/Bryston-4BST-
    Testing
    Testing
    Testing
    treitz3 Posts: 19,986
    I have an upgraded by Klaus Odyssey Stratos up for grabs that might be right up your alley. Food for thought, nothing else.
  • kawizx9r
    kawizx9r Posts: 5,150
    I'd say a Moscode 300 (modified) or a stock 600, if you can find one that is.
    Go with the 300 if you're not going to use it to power 8' electrostatic speakers at high volumes, other than that you'll be set for a while :D
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • george daniel
    george daniel Posts: 12,096
    Belles 350a Reference.
  • Jetmaker737
    Jetmaker737 Posts: 1,116
    danz1906 wrote: »
    These amps are highly rated but kind of old. And Aragon is out of business. Would it be risky to pick one up in case something broke?
    treitz3 wrote: »
    I saw that one in the FS section. Wasn't somebody lined up to buy it?
    Yes, actually. I got a shipping quote from UPS and the shipping was 10 bucks shy of 2 bills. WTF? Then life happened and to be honest with you? I completely forgot about getting another quote. You are correct though.
    Perhaps a move up the Halo chain to the Halo 21 (parasound)!
    cnh
  • tcrossma
    tcrossma Posts: 1,301
    I went from a B&K to a Belles Reference 150A (a very good amp btw), and finally up to a Pass X150, which is where I'll stay for the foreseeable future. It has everything you're describing, and was a very good bump up from the B&K. Unfortunately, both the Belles and the Pass are above your $1k mark -- sorry.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • phuz
    phuz Posts: 2,372
    What preamp did you use with all of these?
    Instead of different amps, you might want to try different preamps, or a different source. Your'e using a tube pre *and* a tube CDP. This could be the reason you're missing some detail and having problems finding a synergy with various amps.
    Consider different tubes in your preamp as well.
    For the most part, an amp is only as good as what you send to it.
  • phipiper10
    You raise a good point Phuz. It's true I haven't changed out the CDP/Pre as frequently. The pre primarily stays for it's versatility of having remote and HT pass and lots of inputs (and tubes). It seems to be a relative bargain at the used price. I did try 5 sets of tubes and ended up happy with the cheaper Philips set. (Drew has me thinking about a cap upgrade)
    I do have a few Pre's on my "list" but they are all over a grand to maintain the attributes above. The rig has to perform HT/2ch duty or else I'd have more options.
    The CDP, the original Bada, was a major upgrade over what I had. I think the sentiments around here are a a mix of "chinese junk" and killer for the price. Guess I'm in the latter group.
    Thanks, your thinking has at least brought a new perspective to the upgrade path.
  • phuz
    phuz Posts: 2,372
    I'm sure it's a fine pre and CDP, I just think that synergy might be the issue and searching for the perfect amp to go with everything you have upstream might be a very daunting task.
    I'm more of a believer of neutral sources, and then finding the right synergy between a pre and amp, with relatively neutral or well rounded speakers. I think with two tube stages before your amp you may have a difficult time finding what you're looking for in an amp alone.
    Interesting reading though. I'd be curious to see where go you from here!
  • thuffman03
    thuffman03 Posts: 1,325
    +1
    I love mine so much I bought a second one.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Jeff_J
    Jeff_J Posts: 21
    GV#27 wrote: »
    I'll second this! I had a Bryston 3B hooked up to my system for one night. Unfortunately I had to sell it the next day though, as my only intention was to pick up this unit off of CL and quickly flip it for a very healthy profit(I needed to generate some quick cash in order to buy the B&K Ref 50 S2). I do remember that the amp kicked **** and was physically very small in size compared to say an equivalent Adcom unit, but its construction and sound was top-notch. It definitely sounded better than my 555II.
    My stereo system: Usher CP-6311, Denon AVP-8000, Adcom GFA-555II, Sony CP-C725, Furman PL-Plus.
    Built and gave this system to my dad: B&W CDM-1SE atop Krell LAT-2 stands, Proceed PAV-S, Adcom GFA-555II, Denon DVD-2500.
