How to embed a You Tube video
heiney9
heiney9 Posts: 25,398
edited November 2009 in The Clubhouse
As the title says.
I must be missing something simple but I can't seem to figure it out. Can someone please explain?
Post edited by heiney9 on
  • BIZILL
    BIZILL Posts: 5,432
    this gets me all the time, though as i recall, it's rather simple to imbed. you're not alone heiney.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Pauly
    Pauly Posts: 4,519
    There is an option to the right of the video with the embed code. Just copy and paste.....
    Pauly
    Life without music would
  • BIZILL
    BIZILL Posts: 5,432
    Pauly wrote: »
    Pauly
    i've done that in the past. i think where i went wrong was the ones i tried to do where somehow locked out? are there instances where you copy said code yet it still won't work on this site?:confused:
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
    Pauly wrote: »
    Pauly
    The embed code is HTML and HTML isn;t allowed on CP.
  • Pauly
    Pauly Posts: 4,519
    <object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/KylF4mZXf1Q&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/KylF4mZXf1Q&hl=en_US&fs=1&&quot; type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
    Its only allowed in the Clubhouse....
    Pauly
    Ah, I see
  • Jstas
    Jstas Posts: 14,971
    The embedding code is not HTML, it's XML.
    The Clubhouse forum allows videos to be embedded but the other forums do not.
    To embed video, wait for the video you are watching to finish. If the author/submitter/owner of the video has allowed embedding, there will be two sections to the right of the video. One is the URL for the direct link to the video. The other is the XML code for embedding the video in an HTML page. If you are watching the video on YouTube.com, there will be sections to the right under the video information section and you do not have to wait for the video to end.
    The direct link URL is just that, a link. If you post it in a vBulletin or phpBB bulletin board, the software recognizes it as a link and treats it as such. If you are using it in an HTML document, you need to use the HREF tags around the link for it to show properly.
    If you are embedding the video, all you have to do from YouTube is highlight the embedded video code, right click and select copy. Then open a new post window in the Clubhouse and paste the video code in the text box where you would normally put your post. Click "Preview Post" to ensure the video shows up. If it does, post away. If not, go back and copy the link instead and post that.
    Embedded code does or does not work based on how the admin of the message forum you are participating at has setup up the forum to behave. If the video was not allowed to be embedded by YouTube the embedding code would not be available and there would be a message stating that the author has requested that embedding be disabled.
    Expert Moron Extraordinaire
    Yeah, I understand now. I was trying to post a video in the Movies and Music forum and copying the XML imbed code didn't work in that forum. Thought there might be a way around it.
  • Pauly
    Pauly Posts: 4,519
    heiney9 wrote: »
    **** to Patrick... ;)
    Pauly
  • Jstas
    Jstas Posts: 14,971
    I've been bitching to Justin and now Patrick for a while now.
    The Music and Movies forum is where it makes the most sense to have the ability so things like movie trailers can be posted or music videos.
  • Pauly
    Pauly Posts: 4,519
    Agreed....
    Pauly
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Jstas wrote: »
    The more people that **** usually the better results ;)
    By the way, thank for the clear information on embedding process (the why and why not).
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • John30_30
    John30_30 Posts: 1,024
    like dis?
    <object width="480" height="430"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.theonion.com/content/themes/common/assets/onn_embed/embedded_player.swf?image=http://www.theonion.com/content/files/images/GLENN_BECK_ARTICLE_10_29.jpg&amp;videoid=98957&amp;title=Victim In Fatal Car Accident Tragically Not Glenn Beck&quot; /><param name="wmode" value="transparent" /><embed src="http://www.theonion.com/content/themes/common/assets/onn_embed/embedded_player.swf"type="application/x-shockwave-flash&quot; allowScriptAccess="always" allowFullScreen="true" wmode="transparent" width="480" height="430"flashvars="image=http%3A%2F%2Fwww.theonion.com%2Fcontent%2Ffiles%2Fimages%2FGLENN_BECK_ARTICLE_10_29.jpg&videoid=98957&title=Victim%20In%20Fatal%20Car%20Accident%20Tragically%20Not%20Glenn%20Beck"></embed></object><br /><a href="http://www.theonion.com/content/video/victim_in_fatal_car_accident?utm_source=videoembed">Victim In Fatal Car Accident Tragically Not Glenn Beck</a>
  • Pauly
    Pauly Posts: 4,519
    heiney9 wrote: »
    Think hes got it guys.......
