Wiring mono amps
Rennrig
Hello Polk Land,
I am going to purchase interconnect cables and speaker wire for a 2 channel, 2 speaker installation. With Mono amps, should I spilt the difference in distance between the source and speaker by placing the amps in between and having equal distance inter connect AND speaker cables?
For instance, lets say the speakers are sitting six feet to each side of the source rack. Should I place the mono amps on stands in between the source and speaker and purchase equal length 3.5 ft cables? Or does it not make a hill of beans of difference?
Rennrig
Rennrig
Post edited by Rennrig on
the best set up in theory would be to have the amps as close to the speakers as possible to shorten the speaker cable. Although, i doubt in practice you'd notice too much of a difference with that short a distance.
What Wes said,,just make sure that you do not have really long runs of interconnects from your pre to your amps.JC approves....he told me so. (F-1 nut)
Right on...I have my 565 monoblocks on stands beside my amps with 3 foot runs of speaker cables.It looks cool too.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Thanks Folks, this sounds good.
Is there an optimum distance good speakers should be placed apart for 2 channel listening? -
Equilateral triangle for 2ch listening. Ideally at least 6ft apart.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
