adding a PSW10
coolsax
I currently have a PSW505 on my system but my avr allows for 7.2.... Frys has the PSW10 on sale for 88 bucks this weekend so i'm very tempted to pick this up as a 2nd sub.. what do you think.. will the 505 drown it out or will it still had a nice stability to my bass.
Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22
TV 3.1 system -
Post edited by coolsax on
Yes, i think the 505 will drown it out reardless of placement. i currently run 2 PSW10's and they sound nice together, i would keep em the same for sure.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
The 505 is much more powerful and may do this...but lots of people double stack their subs on top of each other....the PSW10 although it only has a bottom end of 40hz is actually OK for "music" because of that..if it is NOT overdriven. because it will then put out port noise...
It might be worth experimenting? Who knows for sure?
Honestly i wouldn't bother. It won't give you much other than possibly a nasty volume spike in the frequencies where the PSW10 might actually be able to halfway keep up with the 505.
Now, if you could use the PSW10 as a dedicated mid-bass woofer, and the 505 as a true sub, that might get you somewhere, but i think that's be more trouble than it's worth using subs of that caliber.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
thanks guys I thought that might be the case but for 88 bucks I thought it worth the ask
Main 2ch -
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
I tried to run PSW505 and PSW10 before and I did not like it at all. You will degrade the SQ of PSW505 by adding muddy PSW10.Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1.
