RTA 15's?
  • ESavinon
    ESavinon Posts: 3,067
    edited November 2009
    Polkie2009 wrote: »
    Haven't seen this series in years,just have to ask how do the RTA-15's compare to the LS90's?
    Very similar sound but i'd choose the LS-90 over the RTA-15tl.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • igotitiscool
    igotitiscool Posts: 2
    edited June 2014
    Hey i know its been 7 years for this thread but how much at RTA 15's worth now, i got a chance of getting a pair
  • Dropthebeat
    Dropthebeat Posts: 154
    edited June 2014
    I bought a pair from an old lady in dallas, 120 dollars !!! but i believe anything bellow 300 would be a good deal .
    Yamaha V1800 receiver along with a NAD 2600a and 2700a .
    Sda 1c - my new favorite speakers
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Marty sub 18" still in the works
    Klipsch sw12-2
    Hobbies turn into addictions .
  • nikogto
    nikogto Posts: 2
    edited June 2014
    I just picked up a pair of RTA 15TL's this last weekend. Some younger guy had them and I traded him a radiator I had on CL for them. Not too bad of shape cabinet wise, got them home and hooked them up in my garage off an old (20 year old optimus receiver) receiver, neither tweeter worked, pulled them out, on was hooked up but inop, hooked up a infinity car speaker to the wires to check, that worked, tried the other side, pulled tweeter and wires were cut to it, got to check and see if the wires from the crossover still power a speaker. I've seen some replacement tweeters on ebay, any decent ones out there to install without spending a lot of coin? All the drivers seem to work, not much power out of the old receiver (110 watts ch) but when turning them up, they didn't hit all to well. Any driver replacements? I can always get some tweets first and see how it sounds.
  • Sea
    Sea Posts: 317
    edited June 2014
    What if any is the difference between 15 and 15tl? Does the addition of the "tl" designation on all of the models simply delineate the change to SL3000 tweeters?
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
    pitdogg2 Posts: 27,016
    edited June 2014
    nikogto wrote: »
    call Polk customer svc. and order rdo-198 replacement tweeters. those RTA15's will hit very hard you need a amplifier for those no receiver will ever do them justice. Feed them very good power and hold on.
    edited June 2014
    Sea wrote: »
    The RTA 15tl came out after they had switched to a tri-lamate tweeter so they all would of been TL's. Some also say that the T stood for "tower" on the boxes that said RTA15T.
    EndersShadow Posts: 17,704
    edited June 2014
    nikogto wrote: »
    What he said. I have the RTA 11TL's and enjoy them very much. I have also seen the RTA 15TL's and they looked cool and sounded good. Couple notes.
    1. They need to be placed a bit out into the room. Otherwise that rear passive radiator wont work its best.
    2. You need good power. This could be from an older vintage reciever from the 80's, but honestly a better bet would be a nice dedicated amp. I am using a Parasound HCA-750ii on my 11TL's and have yet to get the volume all the way up before I have it loud enough for my tastes. Your 15's really need a dedicated amp. Doesn't have to have TONS of wattage, but something with say 125 to 150 wpc would be a good start. How much wattage you need depends on room size.
    3. As stated the RDO tweeter is a drop in replacement. Polk CS will sell them to you, but let them know your a forum member for a price break on the cost and possibly shipping.
    Sea wrote: »
    Yup, TL indicates it uses a Tri-Laminate tweeter which IIRC the SL3000 is and the SL200 is not.
  • nikogto
    nikogto Posts: 2
    edited June 2014
    I was planning on using them in the garage for music.
  • cincycat13
    cincycat13 Posts: 888
    edited June 2014
    Sea wrote: »
    Some of the early unit looked to have been labelled only RTA15... But in actuality they were all TL and are the same speaker and tweeter combination
