Sunfire Bundle TGA5200 with TGP III
Fernando1
I found this deal in audiogon which is the TGP III and the TGA Grand 5 for $1800.00 both
Can you guys tell me what you think and if this is a good deal or not?
Here is the link
http://www.audiogon.com/cgi-bin/cls.pl?homeproc&1261010826&/Sunfire-theater-grand-iii-proc
Here is the link
Post edited by Fernando1 on
I forgot to ask! Can this TGP III be used for 7.1 or is it just 5.1
Also does the processor have DTS ES, DTS neo6, Dolby EX, Dolby prologic IIX? -
It is not a bad deal. The amp is 225 wpc into 8 ohm and 450 wpc into 4 ohm. The processer is three generations old but still formatable.
Depending on demand and condition the amp goes for 900 to 1200 and the pre goes in the 600ish range.
Also looks like he is footing the bill for shipping and insurance.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
It has outputs for 7.1.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I imagine that since the TGP has no amplifier there will be no heat coming from it?
It will produce a bit of heat.
Though all the Sunfire amps are very cool running. It has to do with the downconverting power supply technology.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
One thing is the sunfire amp in the audiogon classified is not the TGA-5200. Also the TGP III is an older model, after that came the TGP IV and 5, now the latest processor is the TGP 401. In that case I think the price is at the higher end of what I will be willing to pay.
This is a many year old system. For that money I think you can get newer gear. That is just my opinion.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
That is a smokin good deal! You should jump on it. If you aren't interested in all the latest & greatest doodads, this will keep you happy for years to come.
Yes it is 7.1, has all the above processing & has 2 sub inputs.
I know because I have one!:DMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
