Tubes for the Jolida JD-9
Toolfan66
Toolfan66 Posts: 18,014
edited December 2009 in 2 Channel Audio
Where is the best place to find tubes? my unit will be here Friday.
Face and H9 I am counting on you here and of course anybody else that wants to chime in.:cool:
Thanks.
Post edited by Toolfan66 on
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited November 2009
  • Systems
    Systems Posts: 14,873
    I really enjoyed a set of Telefunken 12AX7's in mine. Next were a set of GE 5751's. Have fun. Thats a pretty flexible and user friendly phono preamp. Be careful of the gain settings. I played with my gain settings both for MM & MC until I found the level I liked. I kept the impedence and capacitance as what was called for by the cart manufacturer. I think I may have swapped back and forth from 200pf and 150pf at times.
    Edit...when playing with the gain settings switch back and forth from the high and low outputs on the rear when switching the gain DIP switches.
    Testing
    Testing
    Testing
  • rubin
    rubin Posts: 565
    Like cam said, play with the dip switches.I have the Jolida envoy preamp,which includes your phono pre.I also use the GE 5751 tubes(get rid of the stock Chinese tubes.)Got my tubes from the tube store.
  • thsmith
    thsmith Posts: 6,082
    The Sylvania BP 3mica 5751's are nice
  • NJPOLKER
    OOPS I guess I should have posted the home page, here you go. Brent told me if I order tubes and are not satisfied with the sound can return them and try out another set or pay a nominal re-stocking fee. Pretty good deal I think.
    http://www.audiotubes.com/
    Thanks Guys!!!
  • george daniel
    george daniel Posts: 12,096
    +1 for the triple micas
  • george daniel
    Tele smooth plates are nice, just make you sure you get phono grade and your wallet.
    Looking at pulling the trigger on a set of Bugle boy 12ax7's is $120 ea. to much for them?
    They are new old stock matched pair.
    heiney9 Posts: 25,430
    Tool,
    Sorry I can't help with the choice of 12AX7's. Typically Bugle Boys are very good........be careful there are some fakes going around. That seems high to me @ $120ea, but again I buy the less popular 12AT7's.
    Here's a good resource and I believe he describes what to look for in the fakes.
    http://www.audiotubes.com/12ax7.htm
    My favorite 12AT7 variant is the Telefunken ECC801s. The same Telefunken variant is available for the 12AX7 it's the ECC803s. They are rare and expensive, but damn!!!!! do they sound fantastic!!!!
    heiney9 wrote: »
    Thanks H9! How expensive can they be?
    HOLLY CRAP BATMAN, they are expensive to say the least.
    NOS with boxes about $350-400/pr.
    There may be other 12AX7's or variants that are a better value, I just am not as up on those since I don't use them.
  • george daniel
    Did Cilantro have some Amperex versions/varients for sale recently? Or maybe I have them confused with another tube?
  • doctorcilantro
    doctorcilantro Posts: 2,028
    Hey guys - hey George!
    I currently have a large batch of Amperex 12AX7s made in holland; halo getter and labeled for Electrohome. I put one pair on Audiogon and they really won't last at $99. : ) That's a Polkie price for sure!
    I saw some of the ECC803 Teles go for 1200 about 6 months ago. Yikes!
    You can get the ECC801 for maybe 300-400 as someone said.
    Happy holidays!
    Doctorcilantro
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • headrott
    headrott Posts: 5,496
    NJPOLKER wrote: »
    Here is where I am looking
    http://www.audiotubes.com/6dj8.htm
    I have bought tubes frome here before. Great people and tubes were exactly as described. I can recommend them.
