Room treatments
2
  • RichCanDo
    RichCanDo Posts: 177
    edited October 2009
    I agree with building your own as is much cheaper and you can build specifically only for problem frequencies. At a library you can find books with info on building traps, etc. for specific frequencies.
    Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
    Pre-amp: DBX CX1
    Center: CS1000p Rear Surr.; f/x1000
    Parasound HCA-1205A amp; Center & rear
    Sub: SVS PB12-Ultra
    DVD: Denon 3910
    Tuner, FM: Onkyo Integra T-9090II
    Cassette: Onkyo Integra TA-2090
    VCRs: JVC HD4000U digital, HRS8000U SVHS
    Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
    Conditioning: Monster AVS2000, HTS5100MKII
  • concealer404
    concealer404 Posts: 7,440
    edited November 2009
    Alright... due to budget constraints, i'm going to do something else.
    Still going to make room treatments, but i'm going to try something that was suggested to me by a home theater designer/builder that i picked some cables up from on Friday.
    The project will take place this weekend, it'll be plenty apartment friendly, needing only panels, cloth, staples, and push pins.
    If i hear a big difference like i did in his room, great! If not, i'm only out about $30 for the whole project. :D
    I doubt it'll be to the level of what some of you have done, but i'm more than confident that i'll see an improvement. Wish me luck!
  • ShinAce
    ShinAce Posts: 1,194
    You will hear a difference. Sound absorption is no joke.
    Placement of the panels is almost as important as placing the speakers, so take your time and experiment once you have the finished panels.
  • concealer404
    Yep! I'm going to be making 8-10 panels, and moving them around until i like what i hear.
    The tip i got was just to try Lowe's insulation panels, and cover them with a fairly low-thread count fabric of my choice. They aren't as thick as would be ideal, but i figure they should be well worth the money. This guy's room was dead as a doornail, and i'd be happy with only a 50% reduction in echo/nastiness. The experiment will be worth the $30 even if it doesn't work. :)
  • concealer404
    ^Thanks for links, i think i already had the anandtech one saved, but i saved the other, just in case i feel like these don't do enough down the road. :)
  • nikolas812
    nikolas812 Posts: 2,915
    I'm pretty sure you want a fabric you see through when held up to the light. Or at least be able to blow threw... Pretty much something the same consistency of speaker grill fabric... At least thats what was needed for my panels...
    Nik
  • concealer404
    nikolas812 wrote: »
    Nik
    Yeah, that's what he suggested as well. The girlfriend is having a ball right now going through JoAnn Fabric's website picking out "pretty patterns."
    I figure if i'm going to hang squares everywhere, may as well keep her happy with it somehow. :p
    On the flip side, if i let her dictate ALL my stereo purchases, i'd be running full Emotiva gear, because it's "pretty."
  • ShinAce
    Polyester seems to be a good choice.
  • CoolJazz
    CoolJazz Posts: 572
    ShinAce wrote: »
    Especially if you listen to a lot of 70's music!! :D:D:D
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • polkanddie
    polkanddie Posts: 224
    DIY panels are in my future, I dont want to be evicted you know... Can someone post pics of placement of these, I want to have at least 4 in my room. I think I have some 703 in storage if I remember correctly...
    TV- Insignia 46'' LED,1080p,120hz
    Monster Power center hts3600 mk2
    Onkyo tx sr 503
    Rm6600 with 4 sanus stands
    SUB(DIY)
    Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
    extras... RT10's.rti4s.atrium 5's.
    "sticking feathers up your butt does not make you a chicken"-Tyler Durden
  • fossy
    fossy Posts: 1,378
    I seem to remember a really good post about room treatments not to long ago....search, my fellow polkie, search can be a very good friend
    http://www.polkaudio.com/forums/showthread.php?t=86154&highlight=room+treatments
    Im sure there are more .. but that's the one I remember
  • Face
    Face Posts: 14,340
    How recent are the pictures in your showcase?
    Before adding any treatments, get those silly stacked subs out from between your speakers and pull your speakers away from the back wall.
  • concealer404
    Face wrote: »
    I thought i updated that, my bad.
    The subs are gone, speakers are farther out, but now there's a tv and tv stand between them, but it's behind the front line of the speakers.
    I guess i need to update that further tonite, too.
    I got the materials, but then the girlfriend got engrossed in Prince of Persia: The Two Thrones, so i couldn't do a whole lot last night. I'll hopefully finish and mount them tonite while she's at work.
  • polkanddie
    Im so glad I saw this thread and read up on panel making, I found the pieces of OC in the barn. Very random cuts so I dont think my first panels are going to be the ideal 2x4, But I have a couple 18"x36" pieces. I also found a guy on CL selling some superthin polyester and china silk that matches the couch. I was going to just get some grill cloth but its 7.50 a sq yd at creative acoustics here in raleigh. Just for you guys making any speakers or panels out there I found some silver grill cloth on clearence at mcm electronics at $1.25 for a 36"x60" piece. Anyways I just leaned a couple peices up against the wall and it made a noticeable difference, I cant wait to put these together and mount them. I just want to thank concealer for posting this thread. Otherwise I would not have even thought about this until much later on. :)
    Onkyo tx sr 503
    SUB(DIY)
  • nduitch
    nduitch Posts: 316
    polkanddie wrote: »
    Panels are will not going to stop you from being evicted. Just as much sound is still going to leak out of your apartment into your neighbors apartment. The only thing you can do to help that is to have concrete walls between you and your neighbor.
  • polkanddie
    Uh-oh. I guess I better turn it down a bit then...Thanks for the heads up.
    Onkyo tx sr 503
    SUB(DIY)
  • concealer404
    Mine didn't do much... but i've also only got four 2'x4' panels up right now, and i think i need to try again with better materials. Oh well. Learning process.
  • Hawkeye
    Hawkeye Posts: 1,313
    I've found that room treatments have been by far, the best use of audio dollars, bar none. Better than wires, isolation or coloring my CDs green.
    I have six in my room right now and if the better half would agree, there would be six more at least.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
    SCompRacer Posts: 9,080
    .....i think i need to try again with better materials.
    What material did you use? The last get together we had at my place, I began to remove room treatments while the music was playing. Two attendees treated their rooms the following month. It will be well worth your effort.
  • concealer404
    SCompRacer wrote: »
    The guy that i bought the Scarlet Vipers from actually used foam insulation panels, and his room was ridiculously dead.
    I tried the same thing, and it made a difference, just not real big yet. I'm sure part of it is because of the material i used, and also that i need more panels, and my room is annoying, to say the least.
    I'll revisit this after the holidays and spend some more money on it and see where we stand. This was more of a test run to see if i could hear any difference at all, and to experiment with placement (which i still have to do some more.)
    I still have an echo when doing the "clap test" but it does seem to have subdued some. Voices don't have an echo anymore, so i'll take that as an improvement.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    What kind of foam was used? If you're talking about the pink foam sheathing board, it's more reflective than absorptive. Even acoustic foam is fairly narrow in bandwidth absorption. If you're looking for something equal to OC 703/705, look into Rockwool. ATS has it priced substantially lower than the fiberglass panels. It's fairly easy to work with, I thought it might be less itchy to work with, but boy, was I wrong. DO wear long sleeves!:D Buy an inexpensive bread knife to do any trimming. Don't use one out of the kitchen, you'll dull the piss out of it! (ask me how I know..) LOL
  • concealer404
    Crap, you're talking greek to me again....
    OC 703/705? What's that.... :(
  • polkanddie
    Owens corning, its a brand of insulation. 703 is what is most recommended, or so Ive read...pretty expensive imo. but also worth it in the end. The boards i had laying around in storage were 1.5" thick. I recommend 2" or more. Double layering if you need to. What Im experimenting with right now is 2"soft foam insulation backed with a type of dynamat material and so far it seems to work pretty well. Hopefully it will turn out well when combined with the fiberglass panels. Im debating doing some experiments with rockwool. Gotta look at the costs though... on a budget. lol
    Onkyo tx sr 503
    SUB(DIY)
  • concealer404
    Disregard that, i'm dumb. Forgot that the 703/705 was rigid.
    So i could in theory just cover it and put it up on the wall without building a frame. Not ideal, i know, but building a frame is out of the question for the moment. :(
    I think i'll give that a shot later this month. Bonus check wooo!!
  • LessisNevermore
    Owens-Corning rigid fiberglass panels. 703 and 705, they have slightly different absorption frequency bandwidth. IIRC, 703 absorbs better in the lower bass regions. Rockwool/Roxul/mineral wool is a cheaper substitute, with the same acoustical properties.
    An Absorption Coefficients chart.
    http://www.bobgolds.com/AbsorptionCoefficients.htm
    Also many links to DIY sites.
    Yes. A frame makes it a bit more durable and easier to hang without tearing/sagging.
  • concealer404
    Perfect! I really appreciate it. Down come my silly useless panels and i'll order a case of Roxul tomorrow and try again. :)
  • beardog03
    beardog03 Posts: 5,550
    I use the piles of dirty laundry in my office !!
    works well until wash day !!
    I am glad you posted this thread...
    I will revisit it once i get my office / 2ch room back to where it is supposed to be
    treatments make a huge difference......and you all have given me some useful ideas
    Thanks !!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
