selecting rear speakers.
Can anyone recommend surround speakers that are voice-matched with my Monitor 10 series?
Post edited by pmz123 on
Don't have to worry too much about surrounds matching exactly, but if you really insist what tweeters do your Monitor 10's have?
Go with another pair of Monitor's, or even another pair of 10's if you can find some.
I know you didn't ask about a center channel, but thought it'd help in case you had a question about it - http://www.polkaudio.com/education/showanswer.php?question_num=63
Btw, Welcome to CP!Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Thanks.
I was hoping to find something small. Are RM7, RM8 or OWM3 suitable options? -
If you're looking for small, i'd still try to fit some Monitor 5s back there. They aren't that big, and they'll match better as long as you match the tweeter.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I'll take your recommendation.
Thank you. -
Btw, Welcome to CP!
Man I have searched for that page. Thanks!-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Monitor 4, 5, and 7, preferably with the same tweeters as your 10's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
My 10's tweeters are SL2500. Are those tweeters found in anything other than monitors?
