selecting rear speakers.
pmz123
pmz123 Posts: 6
edited November 2009 in Speakers
Can anyone recommend surround speakers that are voice-matched with my Monitor 10 series?
Post edited by pmz123 on
  • kawizx9r
    kawizx9r Posts: 5,150
    Don't have to worry too much about surrounds matching exactly, but if you really insist what tweeters do your Monitor 10's have?
    Go with another pair of Monitor's, or even another pair of 10's if you can find some.
    I know you didn't ask about a center channel, but thought it'd help in case you had a question about it - http://www.polkaudio.com/education/showanswer.php?question_num=63
    Btw, Welcome to CP!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • pmz123
    pmz123 Posts: 6
    Thanks.
    I was hoping to find something small. Are RM7, RM8 or OWM3 suitable options?
  • concealer404
    concealer404 Posts: 7,440
    If you're looking for small, i'd still try to fit some Monitor 5s back there. They aren't that big, and they'll match better as long as you match the tweeter.
  • pmz123
    pmz123 Posts: 6
    I'll take your recommendation.
    Thank you.
  • vc69
    vc69 Posts: 2,500
    kawizx9r wrote: »
    Btw, Welcome to CP!
    Man I have searched for that page. Thanks!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Face
    Face Posts: 14,340
    Monitor 4, 5, and 7, preferably with the same tweeters as your 10's.
  • pmz123
    pmz123 Posts: 6
    My 10's tweeters are SL2500. Are those tweeters found in anything other than monitors?
