Tsi300 vs Tsi400 @ $250 diff?
lurk01
lurk01 Posts: 1
edited November 2009 in Speakers
So,
am buying a system with Tsi100 surrounds, Cs10 Center and some Towers. Gotta choose between the Tsi300's & Tsi 400's. Local price difference (South Africa) is $250!!!:eek: Is it worth it?
System will be powered by an Onkyo TX-SR507. Will also have a sub (must choose between PSW110 & PSW125, again a $150 difference:confused:)
Post edited by lurk01 on
    Welcome to Club Polk!
    Certainly the 400s are a bit better than the 300s but if you budget for a better sub you won't have to worry about using 300s instead...the sub will pick up the extra low end....so I would spend the money on the better sub and get the 300s!
    Since you're in South Africa I don't think I can recommend the PSW505..? That is available here in the U.S. for about the same coin as the PSW125 and is a more powerful sub..if you can find that at a comparable price, go for it!
    Good Luck,,
    cnh
  • danz1906
    danz1906 Posts: 5,144
    Welcome to the Club!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
