Mirage FRX-S8 sub with new RTiA5's?
d80zoom
d80zoom Posts: 7
I am doing a system upgrade and have an older Mirage FRX-S8 8" Powered Subwoofer that I plan on keeping and will be upgrading my current Pioneer speakers to the Polk RTi A5's and RTi A3's. Is anyone using an older sub with newer speakers, and would there be any problems that anyone can see?
A/V System
Pioneer VSX-D510 A/V Receiver
Pioneer DV-354 DVD Player
Pioneer PD-F1009 CD Player
Polk Monitor 50 Front
Polk Monitor 30 Rear
Polk CS1 Center
RCA 52" Projection Television
Post edited by d80zoom on
  • thuffman03
    thuffman03 Posts: 1,325
    edited November 2009
    I think you should be fine.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Agreed, as long as the Mirage can keep pace with A5's, it will be fine. I don't know that it's going to add a lot to the experience, but it might reinforce the bottom end a bit.
    Cheers,
    Russ
