Which Polk in-ceiling speaker fits the holes in my house?
I hope I have put this question in the correct part of the forum, if not please move to the correct one.
I bought a foreclosure and it has 30 holes in the ceilings/walls for speakers.
About 20 of them are 10 inch diameter circles in the ceiling(s). I would like to buy Polk RC80i for in-ceiling speakers but I was not sure if they would fit. Does the template measure about 10 inches?
I am confused regarding the size of the Rc80i speakers, on amazon they mark them as 8 inch, on the polk website they are talking about 10-3/4" Diameter.
So if somebody could help me on which polk set to buy that would be greatly appreciated.
Thank you
Thank you
Post edited by flapus007 on
Hello and welcome to Polk Audio Forums. The RC80i is a 8" woofer speaker, so Polks quote of 10-3/4" is the overall dimensions the facing and all. Are you sure the holes are 10" seems a little big, but yes most likely a 8" speaker hole.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I couldn't find the link on Polk Audio site as it's no longer a good link, and brings back to where I was.
But on Crutchfields.com site it does list a 9.375" cut out needed for the speaker.
http://www.crutchfield.com/p_107RC80I/Polk-Audio-RC80i.html?tp=193&tab=detailed_info
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
The cutout for the RC80i is 9 3/8", the overall dimension are 10 3/4" x 3 5/8".
Here's the PDF for that loudspeaker as found on the Polk Audio website....page 10.
http://www.polkaudio.com/downloads/manuals/home/RCiManual.pdfCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Check your amp. i believe the rc80i's are 4 ohm speakers. My room is limited for speaker placement and the wife didn't like the speakers sitting around the room so I purchaced TC80i's for front, center & rear. My fron't are directly over the TV & rears are directly over the sitting area. Could not place behind the couch. Sounds Great! Search the web. I found the TC80i's for $139.00 each including shipping
It's effectively an 8ohm speaker, don't even lose sleep over that.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Davidb0123 wrote: »Check your amp. i believe the rc80i's are 4 ohm speakers. My room is limited for speaker placement and the wife didn't like the speakers sitting around the room so I purchaced TC80i's for front, center & rear. My fron't are directly over the TV & rears are directly over the sitting area. Could not place behind the couch. Sounds Great! Search the web. I found the TC80i's for $139.00 each including shipping
That sounds like a trick install...post some pics David.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
dorokusai ... New to this web site ... 15 minutes now. not sure how to post pics
If you host the pics elsewhere you can just post a link here.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
