Which Polk in-ceiling speaker fits the holes in my house?
flapus007
flapus007 Posts: 1
edited November 2009 in Speakers
I hope I have put this question in the correct part of the forum, if not please move to the correct one.
I bought a foreclosure and it has 30 holes in the ceilings/walls for speakers.
About 20 of them are 10 inch diameter circles in the ceiling(s). I would like to buy Polk RC80i for in-ceiling speakers but I was not sure if they would fit. Does the template measure about 10 inches?
I am confused regarding the size of the Rc80i speakers, on amazon they mark them as 8 inch, on the polk website they are talking about 10-3/4" Diameter.
So if somebody could help me on which polk set to buy that would be greatly appreciated.
Thank you
Post edited by flapus007 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Hello and welcome to Polk Audio Forums. The RC80i is a 8" woofer speaker, so Polks quote of 10-3/4" is the overall dimensions the facing and all. Are you sure the holes are 10" seems a little big, but yes most likely a 8" speaker hole.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • disneyjoe7
    I couldn't find the link on Polk Audio site as it's no longer a good link, and brings back to where I was. :(
    But on Crutchfields.com site it does list a 9.375" cut out needed for the speaker.
    http://www.crutchfield.com/p_107RC80I/Polk-Audio-RC80i.html?tp=193&tab=detailed_info
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    dorokusai Posts: 25,576
    The cutout for the RC80i is 9 3/8", the overall dimension are 10 3/4" x 3 5/8".
    Here's the PDF for that loudspeaker as found on the Polk Audio website....page 10.
    http://www.polkaudio.com/downloads/manuals/home/RCiManual.pdf
  • Davidb0123
    Davidb0123 Posts: 10
    Check your amp. i believe the rc80i's are 4 ohm speakers. My room is limited for speaker placement and the wife didn't like the speakers sitting around the room so I purchaced TC80i's for front, center & rear. My fron't are directly over the TV & rears are directly over the sitting area. Could not place behind the couch. Sounds Great! Search the web. I found the TC80i's for $139.00 each including shipping
  • dorokusai
    It's effectively an 8ohm speaker, don't even lose sleep over that.
  • dorokusai
    Davidb0123 wrote: »
    That sounds like a trick install...post some pics David.
  • Davidb0123
    dorokusai ... New to this web site ... 15 minutes now. not sure how to post pics
  • dorokusai
    If you host the pics elsewhere you can just post a link here.
