6511 Drivers
flason
I'm in need of 2 6511 drivers for my SRS 2.3's. I removed both and both are marked 6511 and Sept 1988. Any help would be appreciateds. Thanks.
Post edited by flason on
Anyone?
I and others on here looked for a long time for used MW6511 as they are rare, I believe that Polk still sells them new for 48 shipped to forum members, Only problem is they are not an exact match visually but do sound the same.
Attachment not found.
See the difference from the new one on the right? not drastic and most (common) people will not notice. You can also try your luck on e-bay, I found one and so have others.
Good luck.
