Tubes
heiney9
heiney9 Posts: 25,724
edited November 2009 in 2 Channel Audio
I bought a lot of 7 tubes from a very nice lady in Germany. I was really only interested in a particular matched pair of Valvo's and the rest were a bonus. All the tubes tested between 75-90% of NOS according to the seller and at this point I have no reason to not believe.
I finally put in the pair of Valvo's and one is pretty noisy. Lots of low level hiss and occasional soft popping. It seems after they warm up for about 30 minutes they are much quieter and no popping, but still some low random hiss.
I cleaned the pins with deoxit. Is there anything I can do to quiet these down or is this a sign they are on their way out? I am working with the seller for a partial refund...........but as usual I'd rather have working tubes than the $$$. These are among the rarer Valvo's produced and I'm hoping there is some way to salvage them.
  • Flash21
    Flash21 Posts: 316
    edited October 2009
    I guess that's just the "soul" talking (re: your sig) :p
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    well if its just that one tube then that would seem to narrow it pretty good, have you damped the tube....if it gets better as it warms then it may be very slow to reach optimum bias.
    RT1
    edited October 2009
    I haven't dampened the tube and actually when I first installed them...........before cleaning the pin's, it was just one tube, after cleaning they both were acting up, but the original one was acting up more. So dampening can help this issue? Tonight when I get home I'll install them and let them sit for a good hour and see if they quiet down. After cleaning and re-installing them they were so noisy and were popping I only left them powered up for about 15 minutes.
    I even put in a different rectifier because I thought maybe there was a mismatch, etc. That didn't help at all. I've since put in a couple different pairs of tubes with no issue so I doubt it's the pre-amp.
    F1nut Posts: 52,406
    edited October 2009
    Yes.
    edited October 2009
    Yes.
    That's what I thought. Is it possible they could test well (as in the good section) and still be on the way out? Seems like a silly question, but since I don;t have a tube tester I have no experience with how the testing relates to real life use.
    I have access to a tester here in town thru a member of our Rockford audio group.
    Bummer, because I really like the sound of the late 50's Valvo's made in Hamburg of which these are.
    mhardy6647 Posts: 35,562
    edited October 2009
    It is thermionic noise based on the description. Are they high gain tubes like ECC83s? Sort of comes with the territory (although of course some are noisier than others).
    edited October 2009
    ECC81/12AT7.
    Please explain further
    edited October 2009
    Hiss is usually random (shot) noise from the electrons cooking off the cathode and impinging on the plate. 12AT7 isn't really high-gain, so I basically rescind my conjecture.
    edited October 2009
    These are unlistenable. The hiss/popping is pretty loud. When I get a chance I'll roll them in and let them power up for an hour or so and see if they quiet down.
    F1nut Posts: 52,406
    edited October 2009
    That does seem to be the case here.....would explain the popping as well.
    F1nut Posts: 52,406
    edited October 2009
    Depends on what they were tested for and on what they were tested.
    The seller on Ebay has made a partial refund for the noisy tubes. Very nice and accommodating seller from Germany. She had a little issue with English, but a very nice lady with excellent communication.
    Another great E-bay transaction.
