can a subwoofer damage speakers
tschep20
If a subwoofer like a svs pb2-isd is very close to a speaker (like right next to it by a few inches), can the sub damage it in any way?
Post edited by tschep20 on
No, unless it is an electrostatic or a ribbon and even then unlikely."What we do in life echoes in eternity"
SVS -
If the PB2 takes out a loadbearing wall it could cause some damage:D
God I want one -
i can only imagine what it would do to a computer screen, my rti150s make my screen vibrate....that cant be good
Doc,
Not to make a big thing, but are you sure?
I was told in my now long ago college days that our dorm rooms were not "speaker friendly". Our individual rooms were about 10 x 18' and most of us set our speakers facing the long wall on a heavy duty shelf over our desk. The drivers ended up starring at a heavy plaster wall about 8' away.
Anyway I was told at high volumes the reflected waves could actually increase the work load on the woofers, putting them in peril... An extreme set-up situation to be sure, but at 100+ db I could see the reflections being an issue.
Anyway, if there's anything to the above, then I could see relative positions where a sub could make it "unconfortable" for a speaker to do its work...More later,
Tour...
Vox Copuli
I suppose if you took the front firng woofer of a sub and stuck it in the face of the mid range driver of a tower they could work against each other. It's kind of a bizarre scenario, though.
You are correct in thinking along the lines of drivers working harder against a close surface or against internal enclosure resistance. A sealed driver always has to work harder than a vented one, for example."What we do in life echoes in eternity"
SVS
