Two subs off a stereo amp
gwh
I want to run two passive subs off an Adcom GFA-555 with the subs in opposite corners. The additional sub will be within 5 feet of my listing area while the other will be about 10 feet away. Pre-pro only has one sub out so I need something in-line to adjust the volume on one of the subs.
Something cheap....any ideas?
Thanks,
G
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
Do you have a pre/pro with 2 sets of preamp outputs? That'll require you of course to setup some type of crossover, otherwise all I can think of is a y-cable from the pre/pro's subwoofer output to the L/R rca inputs on your amp. Your pre/pro subwoofer volume/regular volume should regulate how loud your subs will be in relation to the rest of your speakers.
I'm just wondering about phase issues now...
-Freddy
P.S. Btw, if you do utilize the subwoofer pre-out on your pre/pro, remember that the only way you'll be able to fine tune the cut off/etc. will be from that pre/pro.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Just one, it's an Outlaw 950.HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
I have the 950 it will work fine
