Tube pre amp
13
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2009
    Well it's mine :) I call him earlier tonight and he's not young, he doesn't sell nothing since he doesn't sell but buys new stuff to keep it forever. Not the cheapest pre amp, but I know what this pre amp can sound like. :D
    http://www.audiogon.com/cgi-bin/cls.pl?preatube&1260765326&/Conrad-Johnson-PV-5-Tube-Pream
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2009
    I've bought from zero(0)'s before but I know how to handle business...as a rule, just be safe and use communication and common sense as your guide. I was a zero on Audiogon, eBay and here one time....thank goodness that was ages ago :)
    Congratulations Steve. It's about time you get off your **** in regards to audio....and you really don't have any excuses so save 'em. That's a wonderful pre-amp.
  • disneyjoe7
    edited October 2009
    I know I heard this pre amp and my new Amazing speaker on PF04? at Troy's house, I never forgot it. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    edited October 2009
    disneyjoe7 wrote: »
    Yes, 2004.
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Wow man, congrats on the score. I can't wait to hear what you think.
    I have never heard any C-J stuff but I have stared at it and wondered.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Systems
    Systems Posts: 14,873
    edited October 2009
    I see another happy CJ owner in the makings. I wish we lived closer. You could scratch your amp itch with the borrowing of some MV75-A1, MV60SE, Premier 11, MV125 goodness. I still own quite a few other tube amps from other makers but I'm stuck on CJ for now.
    REMEMBER! Be sure and check that this preamp has an inverted output signal. READ THE MANUAL! You will make all the connections as you would for any other standard preamp and connect to your amp as usual. All you need to do is reverse the speaker phase when connecting. + from amp goes to - on your speakers. If you use a turntable you'll also need to reverse the phase at the connections to the cartridge. Thats easy too using a small pair of tweezers or hobby pliers.
    Don't forget to write a review.
    Enjoy!!
    Testing
    Testing
    Testing
  • janmike
    janmike Posts: 6,146
    edited October 2009
    Congrats Steve. Hope all works out.
    Michael ;)
    NORTH of 60°
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2009
    187CAM wrote: »
    Unless you have SDA's, in which case you should NOT invert the wires at the speakers.
    SOPA
  • disneyjoe7
    edited October 2009
    187CAM wrote: »
    Enjoy!!
    Do I need to worry if just 2 channel? I was thinking not. :confused:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Systems
    edited October 2009
    Yes you do. Read the manual carefully. Then if you are still unsure call 703-698-8581. They are more than happy to talk about the older CJ units. They love to see them still being enjoyed. You can also contact Bill Thalman of Music Technology (703-764-7005) with questions. Be sure and ask about the inverted signal for the turntable on that preamp also.
    Testing
    Testing
    Testing
  • Systems
    edited October 2009
    From my PV12 manual:
    MAIN OUT: Connect this output to the input of your amplifier (or crossover in a bi-amped system). We recommend the use of an amplifier with an input impedance of 20k ohms or higher. Since the PV12 line stage inverts phase, it may be necessary to reverse the connectons of your speaker leads to maintain correct phase. See the section on "Getting the Most Out of Your PV12" for an explanation.
    Copied from the "Getting the Most Out of Your PV12" section:
    The PV12 is phase inverting. If your system has an odd number of inversions, (for example, if the PV12 is the only phase inverting unit in the chain) then you must add one phase inversion. This is conveniently done by reversing the positive and negative connections to your speakers (be sure to reverse both channels).
    Testing
    Testing
    Testing
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    I am puzzled by the phase inversion. Why would they do that? To avoid correcting it with more circuitry? Any idea?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Systems
    edited October 2009
    Back in the day many components were phase reversed. Especially CD players.
    Testing
    Testing
    Testing
  • disneyjoe7
    edited October 2009
    Ok still confused about this phase inversion, why bother if the speakers are the only thing playing? It's not like you need to be in phase if you're the only one inverted.
    God no I just didn't post that. :(
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    187CAM wrote: »
    So, in short, C-J was compensating for a potential flaw in other components? Or is it a case of: Two C-J components would be "in-phase" without the need for for speaker wire inversion?
    I am still puzzled by why they wouldn't just make their components phase aligned.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Systems
    edited October 2009
    Call Ed at CJ and ask him. 703-698-8581 he has a simple explanation for this. Nothing to be worried about.
    Testing
    Testing
    Testing
  • Ricardo
    edited October 2009
    You can always ignore it. Having both speakers out of phase will give you the same sound anyway.
    Those that say that they can hear a difference will chime in of course ;)
    SOPA
  • Systems
    edited October 2009
    Just enjoy the damn PV5. As stated in the manual you can switch between the phases to suit your listening.
    Testing
    Testing
    Testing
  • disneyjoe7
    edited October 2009
    187CAM wrote: »
    I like the "May be Necessary to reverse the connectons", and yes I agree if you have the pre amp with other speakers working with other source pre amps, but if alone I don't see why.
    Ok we cool.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    [QUOTE=disneyjoe7;1175618 It's not like you need to be in phase if you're the only one inverted. [/QUOTE]
    I could make so many funny Brett/Disney lines outta that one, signature stuff for sure.............
    Your on your way, damm you stayed on that fence forever, there will be know turning back and this is a great way to jump into a tubed preamp.
    RT1
  • disneyjoe7
    edited October 2009
    It's shipped. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited October 2009
    I got it today, and I say I can't remove the smile off my face. I'm in LOVE baby :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • hoosier21
    hoosier21 Posts: 4,415
    edited October 2009
    disneyjoe7 wrote: »
    right on enjoy
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • disneyjoe7
    edited October 2009
    Also must add this seller is OK with me, sweet condition never would believe this pre is 26 years old. More like new, not a mark on it, not even dust in the unit... nothing at all.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • george daniel
    george daniel Posts: 12,096
    edited October 2009
    Ricardo wrote: »
    Which brings up a good point,, wonder how many SDA owners are using phase inverting pre's and don't know it?Also,, lets say you had a phase incerting pre with a dac that reverses phase in the chain,could you simply reverse the phase on the DAC to correct the inverted phase of the pre,,and thus use SDA's?
    Congrats on the pre DJ,, is it in the Amazing's rig?
    Enjoy.:)
  • Systems
    edited October 2009
    I know the feeling. Give it a few days then write a review.
    Testing
    Testing
    Testing
  • disneyjoe7
    edited October 2009
    Yes the CJ PV-5 pre amp to a Parasound / Halo A23 amp to the Amazing speakers. I'm in LOVE. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • janmike
    edited October 2009
    Congrats on the new addition Steve. Enjoy.
    Michael ;)
    NORTH of 60°
  • inspiredsports
    inspiredsports Posts: 5,502
    edited December 2009
    I decided to resurrect this not-so-old thread instead of starting a new one as my recently purchased (phase inverting) vintage Conrad Johnson PV-7 tube preamp arrives tomorrow.
    I will be connecting the preamp to my SDA SRS 2's through a non phase-inverting amplifier, so by Conrad Johnson's instructions, I should be connecting red to black and black to red at the speaker terminals.
    I noticed Ricardo (back in post #69) says DO NOT reverse speaker polarity if you have SDA's. Others say call Conrad Johnson or Bill Thalmann. I'm guessing after I go through all of that I will still have 2 (or more :)) different opinions.
    What have others in the group done in this situation, and what were the results?
    Thanks in Advance,
    Greg
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • george daniel
    I have connected phase inverting pre amps to my SDA's unknowlingly,and knowingly, suffered no damage,, I have tried it both ways(switching speaker wire connections.), and could not really tell a difference.If you feel uncomfortable, then by all means contact Mr. Thallman first.IIRC, there was a C-J connected to Troy's SDA's at Polkfest,and I think it was phase inverting,,in fact it might have been Steve's.You might wanna shoot him a pm.For the record,my current pre in my SDA rig,does NOT invert phase.Keep us posted as to what you find out,please.
