rt55i
chuckde
chuckde Posts: 6
edited September 2003 in Speakers
i blew out the tweeter on my rt55i the other day. its still under warranty, and i was wondering how to go about getting it replaced. for that matter, how do i get it out of the plastic covering its snapped into without damaging something?
also, i just got my first paycheck and im thinking about putting together a home theater. any suggestions? the only things ive got set right now are the 55's and the dvd player. my current receiver is a technics SA-DX750, but im probably gonna upgrade it.
Post edited by chuckde on
  • setzer808
    setzer808 Posts: 173
    Not sure about your replacement questions, but so far as building a home theater...you will get some great service from those 55i's. I use a pair for my mains and they are great! Partner them with a good sub and you are set.
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
    Polk PSW-350 Sub -in storage.
    Yamaha RX-V681 A/V Reciever
    Sony SCD-CE595 SACD Player
  • dorokusai
    dorokusai Posts: 25,576
    Welcome to the forum.
    Post your replacement question in the Troubleshooting forum, you will get the help you need in there.
    There are some great prices on the RTi line right now, check your local audio/video stores.
  • TroyD
    TroyD Posts: 13,124
    I would suggest giving Ken Swauger or any one of the folks at Polk customer service a jingle. They will be MORE than happy to point you in the right direction
    BDT
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Remove the bezel with the proper Torx screw, then, believe it or not, just use a small flathead screwdriver to 'pop' the tweeter out from the rear.
    Cheers,
    Russ
  • burdette
    burdette Posts: 1,194
    Originally posted by RuSsMaN
    Remove the bezel...
    Torx screw...
    from the rear...
    Was I the only one that picked up something Freudian in that post?
    In the words of Nefertiti... not tonight, it's my pyramid.
    Did you hear about the guy who got his vasectomy done at Sears? Every time he gets aroused, the garage door goes up.
    VR3 Posts: 29,401
    Here is my step by step tutorial on how to remove a Polk RT tweeter. Enjoy..
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=12227
