Kimber Kable Digital X
mantis
OK,
so I needed a new digital 1m cable and took the trip down to the Local Kimber Dealer.They had a very limited selection of KimberKable and I didn't notice the usual.So there it was a Digital X coax digital cable.It was thinner then usual and had the black braid on it like the Hero's do.Usual Kimber ends there own not WBT's.
Anyone know if this is a new things to come?Nothing on the Web site.
I picked it up,took it home and gave it a run.So far I can't hear any Diference between my Transparents,Monsters and now Kimbers Digital coax........I think this is a dead end.They all sound exactly the same,no difference whats so ever.They all have different built quality.I assume they all can fully transfer the signal with no interference.Why else would there not be any sound quality difference?
Dan
Post edited by mantis on
IMO, digital signal is a simplified version of the original analog signal. Digital should have less problems getting from one place to another. Analog cables carry more information and this is why IMO they make a difference. I hope that Kimber didn't cost you too much $.
Maurice -
Hey Mantis,
You would think though that once you get to a certain level of technology, especially somthing as base as cable...you kind of hit a cieling, a limit as to how well a cable transfers information. I mean it's not like a pre amp, with it's path and all the parts.
The biggest difference I noticed in my cable upgrades is the Kimbers I put between my amp and pre amp. I went to pure silver on my coax from the DVD /CD and there was a little more info there, sound traveled from one speaker to another clearer but not dramatic as I had hoped, but my previous cable was far inferior cable than what your swapping out.
StuffYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube -
STUFFMD,
I hear yeah.I have been dicking around with wire for years.I'ts what sounds the best in what system at the level I'm at.Some systems I perfer Transparent over Kimber and Visa Versa.Digital cables I have now tested to many.I can't tell the damn difference and I have a prety cridical ear.Analog is a totally different thing.Speaker wire and interconnects I can hear many differences between different companies.
I'm sure you know my opnions.Gear is major and wire is fine tuning.Matching is key.Dan
You know I'm with ya all the way Mantis. Cable and wire matching is as important as speaker/ equipment matching. I just ordered a pair of Oval Ones,just for fun, my buddys were busting my balls because I already have the Kimbers.... I just like swapping out and tweeking the sounds.....see what happens...Hell it's a hobby.
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
PS2/Gamecube
