Just picked up an Adcom GFA-5800 (broken)
2456
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    Is the 5800 an NP design? I agree with the matching of the transistors as well as the resistors. It is not an easy under taking for the average DIY guy. It is one more piece of equipment. I paid a little over $100 for my beta tester used.
    Ben
  • Systems
    Systems Posts: 14,873
    edited October 2009
    ben62670 wrote: »
    Yes
    I agree with the matching of the transistors .... is not an easy under taking for the average DIY guy.
    And can get costly if you need a large sample group to get your desired matches.
    Testing
    Testing
    Testing
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2009
    Are the Mosfets shorter or otherwise bad? Do we know at this point.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    heiney9 Posts: 25,425
    edited October 2009
    ben62670 wrote: »
    Yes, and I was just saying what the absolute best way was. I realize it's difficult for an avg diy'r. I know you can pay extra to have them matched from some suppliers.
  • mmadden28
    mmadden28 Posts: 4,283
    edited October 2009
    Hey guys--
    I went through the schematic and tested every part-and removed some from the circuit where parallel resistance factored in just to be sure. Essentially not much more wrong than I originally found--So far all the 16 previously mentioned resistors are open, found a flaky Zener and one other open resistor. All 8 transistors on the affected half are shorted. All fuses are intact. There are a couple other zeners that aren't measuring as expected, but they are beyond the path of the damage and I haven't taken them out of circuit yet--perhaps later tonight.
    So at least I now know the extent of the damage. I'll post a pic of the schematic marked up with good and bad parts in a bit. Maybe somebody can figure out what could have caused the failure to begin with based on the path of damage.
    I already removed all the bad parts and the good resistors that I'm going to replace anyway. And am cleaning the board now.
    I found Nelson Pass's article on testing MOSFETS, and ironically in the article he uses the same transistors that are in the 5800 as samples for the test. The tester will enable me to calulate the Vgs for each transostor under test. I'm building the tester now to test all the other transistors and to get the Vgs baseline.
    Nelson Pass commented on my post at DIYAudio and indicates the need to match the replacements--in that post and according to the MOSFET testing article I have to match the Vgs ideally less 0.01v, but no more than 0.1v .
    I've determined from the test article and the schematic that the 5800 is a Source Follower or Common Drain design and configured in a parallel layout.
    If I understand this correctly, the all the 'N' side transistor Vgs has to match the 'P' side Vgs. Of course since this is a parallel design, essentially all 16 transistors have to have the same Vgs as each other. This includes one N to another N as well as the N to P. This would be easier if the N and P side were individual pairs but since its setup parallel, they ALL have to be the same. Do I understand that correctly?
    What would happen if they were not matched?
    ____________________
    Pool: Atrium 60's/45's
  • Systems
    edited October 2009
    I suspect his meaning was to match like devices( P-P N-N).Close matching of paralleled transistors will ensure they all draw the same amount of current.You might get lucky and recieve replacements from the same manufacturers date code which should improve the likelihood of them being similar.
    Testing
    Testing
    Testing
  • disneyjoe7
    edited October 2009
    Hmmm.... My thinking would be all N are matched to each other, where the P are match to each other, and they are all complimentary matched to each other. But as far as a killer match not sure 16 would be turf to do, so that my thinking of the 2.0 ohm resistors.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • megasat16
    megasat16 Posts: 3,521
    edited October 2009
    mmadden28 wrote: »
    You'll need to test each Mosfet before using in circuit. The P Channel Mosfets need to match with each other (gm and Vgs) and N Channel Mosfets need to match with each other. Also, gm and Vgs of P and N channel Mosfets need to match closely. In short, all P and N channel Mosfets need to be closely matched for reliable gain, low DC offset and low distortion.
    Most circuits will tolerate unmatched Mosfets or transistors to some extent but your DC offset may become high if it's the case.
    From my experiences and from what I learn from others, you'll get about 20 closely matched pairs out of 50 if you buy transistors and MOSFETs from the same batch (date code, etc.)
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Systems
    edited October 2009
    megasat16 wrote: »
    Matching between parallel devices will help in the long term relability aswell.Offset might be an issue with unmatched P-N devices but most offset in power amps is the result of poor matching in the input stage. Besides his original N channel IRF 244's are date coded 95' so may be difficult to get the new 9240's to match.
    Testing
    Testing
    Testing
  • mmadden28
    edited October 2009
    Interesting...The schematic shows at least 3 transistors (TO92) that are missing from the actual build. There are leads soldered in, but nothing else. Same thing on the working Left channel--I suppose it was a design change at some point. Also the schematic shows the N channels should be IRF240's as opposed to IRF244's. I have to look up the specs yet to see the difference, but I would have expected that if using IRF244s, that they should have used IRF9244's as the compliment in the P stage as opposed to the IRF9240's. Its the same for both channels.
    Everything else appears true to the schematic.
  • mmadden28
    edited October 2009
    Vishay makes a version of the IRF240--a package of 20 for $1380.00 :eek: and with a 58 day lead time. :rolleyes:
    edited October 2009
    mmadden28 wrote: »
    Ha Ha, so it seems not only Polk made changes on the fly and never bothered to print a new schematic. lol
    Nelson is the man, it's great he is so helpful and even has a decent memory about all his designs....He's answered many of my questions is the past as well.
  • megasat16
    edited October 2009
    GV#27 wrote: »
    Yep, it'll be hard to get new devices matched to the old ones. It's cheaper and more reliable to remove all old trannies and use the matched new ones. He can sell some of the old ones and recover a few $$. :)
    mmadden28 wrote: »
    It's much much cheaper buying a working mint condition Adcom GFA-5802 than buying 20 IRF240s. :)
  • Systems
    edited October 2009
    megasat16 wrote: »
    No kidding.
    Testing
    Testing
    Testing
  • Systems
    edited October 2009
    mmadden28 wrote: »
    Maybe it was a supply thing?There was a big mosfet shortage back in the mid 90's. I remember as I was trying to source some back then for my ZEN projects.Many IRF HEXFET's are interchagable given they have sufficient current and voltage ratings for the circuit they will be used in.
    I can't see in the pic but are 244's used in the other channel aswell?
    Testing
    Testing
    Testing
  • mmadden28
    edited October 2009
    GV#27 wrote: »
    :) That Vishay price is insane, but thankfully the IR versions will only set me back about $200 for 16 Q's. Still a chunk of change but I think I'm still ahead value wise. I hope they can pick matched ones--I'll have to call them once I'm ready to order--I still have to get the resistors too.
    Yes 244s were used in both channels instead of the 240s. :confused:
  • Systems
    edited October 2009
    mmadden28 wrote: »
    As I mentioned previous,it may have been a supply thing and the 244's voltage and current rating's were such that it was a suitable substitude.
    Testing
    Testing
    Testing
  • mmadden28
    edited October 2009
    Here's some pics of the prepared board--all cleaned up and ready for new parts
    All contact points (including the fuses) have been cleaned with DeOxit and treated with DeOxit Gold as well. :cool:
    Now while I'm waiting to figure out what to do about sourcing the replacements and then waiting for them to arrive-I'll give the rest of this beast a bath. :)
  • ben62670
    edited October 2009
    Very nice. If you have problems matching them I can help;)
    Ben
  • mmadden28
    edited October 2009
    Here's the schematic. (sorry it was two pages an I don't have the right editing tools on this PC)
    Everything circled in Red was a bad part (Resistors OPEN, Transistors SHORTED).
    Circuit oddities are circled in Orange:
    Q9, 10, and 12 (TO92) were all missing--looks to be a deliberate design change. nothing changed with the traces or signal path, just left open. However there are small leads soldered in the holes which you can see in the second pic in post #49. Not sure if the transistors were cut out later or what. They are missing from both channels.
    C7 and C6 were also missing but replaced with a jumper.
    Also as previously noted, The schematic calls for IRF240s, when IRF244s were actually used (in both channels).
    It should also be noted that R14 (top middle) is a resistor for the ERROR LED. While it appeared fried (couldn't read any color bands), it tested fine-its also outside the main path of damage (and outside the signal path) but will be getting replaced anyway.
    I haven't tested any of the other transistors out of circuit, but none of them were shorted. All other resitors and zeners are good. I had to remove a few from the circuit to test them due to parallel resistance factors.
    So based on the failed part path--any ideas as to what caused the failure?
  • ben62670
    edited October 2009
    Someone touched the negative to positive speaker wire;)
    Once one goes it runs down the line very fast. I know...
    Ben
  • mmadden28
    edited October 2009
    ben62670 wrote: »
    Thanks Ben.
    I'm building the test circuit from Nelson Pass's MOSFET testing article, so that I can determine the Vgs of the IRF244s that are still good. If I can match with just 8 I'll save about $100.
    Here's my protoboard so far--I need to add a few switches for when I make a permanent build out of it and of course use higher wattage parts but...I'll just move the wires manually for now.
  • mmadden28
    edited October 2009
    ben62670 wrote: »
    Without popping the fuse first?
    The fuses are rated 15A, I think the Transistors are rated 20A IIRC.
    And why only half the channel? Why not all 16 Qs? This is one of those parts of the Audio Amp theory I lack understanding in.
  • ben62670
    edited October 2009
    By the time the fuse goes it is usually too late. Hlaf a channel blew on one of my Adcom's too:(
    Ben
  • megasat16
    edited October 2009
    mmadden28 wrote: »
    Well, the previous fuse should have been blown when the trannies are shorted and resistors are opened. I bet the current fuse in the amp is a replacement. The replacement fuse doesn't blow coz the resistors are blown and effectively the shorted MOSFETs are floating and no path for current to flow.
  • mmadden28
    edited October 2009
    megasat16 wrote: »
    I'm sure that's possible. I'll have to see if the fuses are easily found--All 4 output fuses are the same--15A Opaque Gray colored body.
    I'm guessing that the original owner probably didn't take the time to find the correct fuse-(although he did Dynamat the heck out of it, he didn't keep it clean) unless he took it to a repair shop first where they replaced them then gave him the bad news. The box does have a return address label from a repair shop. Maybe I'll call them up and ask what kind of history they have on it and while I'm at it see if they have replacement parts ;)
  • mmadden28
    edited October 2009
    Any thoughts on RCD (RESISTORS COILS DELAYLINES) brand for wirewound resistors? Specifically to replace the 1ohm's.
    It's the only brand (in the specs I need) at Newark which is one source that has both N and P FETS that I would need.
  • Systems
    edited October 2009
    Yes to the RCD's.
    Testing
    Testing
    Testing
  • disneyjoe7
    edited October 2009
    Ok the cost to fix this amp....
    Sorry I been an electronic repair person, your amp IMHO is NFR "Not Feasible to Repair"
    But with all those MOSFET I think it would work like this, and it would be really cheap. Remove every other MOSFET on the left side, also remove resistors. Put them on the other side, with all those MOSFET I would think the amp would be the same watt output. What 5800 amp is now a 2900 amp ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Systems
    edited October 2009
    IMO it is not necessary to replace the 244,s if they are good, I would just buy a few extra 9240's and install the 8 closest matches.
    Testing
    Testing
    Testing
