Amp needed for LSi 15's
pentaquod
Hi,
I am using an Onkyo TX SR 607 (90W/Channel at 8ohms) receiver.
I recently bought a pair of LSi15's. I'm looking to get an amp, but don't have too much to spend right now. I'm looking at getting an Emotiva UPA-2
(125 watts RMS x 2 into 8 ohms, 185 watts RMS x 2 into 4 ohms.)
Can anyone tell me if this setup would be good enough for me to be able to enjoy the speakers?
Thanks very much. Appreciate your inputs.
Post edited by pentaquod on
I just searched online, and I think I have an answer to my own uneducated question:
But your inputs are appreciated all the same. Please let me know if I can find a good amp for a low price...yes I'm a cheapskate!
When you're matching a Power Amp to a PA Speaker, a good rule of thumb is to pick an amplifier that can deliver power equal to twice the speaker's continuous IEC power rating. This means that a speaker with a "nominal impedance" of 8 Ohms and a continuous IEC power rating of 350 watts will require an amplifier that can produce 700 watts into an 8 Ohm load. For a stereo pair of speakers, the amplifier should be rated at 700 watts per channel into 8 Ohms. A quality professional loudspeaker can handle transient peaks in excess of its rated power if the amplifier can deliver those peaks without distortion.
Using an amp with some extra "headroom" will help assure that only clean, undistorted power gets to your speakers. Some professional amplifiers are designed so they have additional headroom. These amps can cleanly reproduce transient peaks that exceed their rated power. In this case select a model with an output power rating equal to the continuous IEC power rating of the speaker. Consult the amplifier manufacturer or owner's manual to learn more. -
Off the bat, 700wpc would be GROSS overkill in your situation.
I'm ALL for it, but you don't need that.
The UPA-2 probably isn't a TERRIBLE choice, but for the money, i bet you could do better.
What's your budget? A solid 200wpc amp should be a great starting point for you.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
pentaquod Welcome to CP.
Good idea to get 4 ohm stable power to the LSi's, unfortunately I do not think the Onk 607 has pre outs that will allow you to hook up an external amp. Is the AVR new enough you can return it? -
Welcome to Club Polk. However, I hate to inform you that you would have to buy a new receiver first since yours does NOT have preouts for a seperate amp. If you had spent more money & gotten the 705 you would be in business.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Hi,
WElcome to the Club!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
You need a AVR with pre-outs, and an AMP with 200w @ 8ohms will
do the job. Maybe a Rotel 1080
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1259502154&/Rotel-RB-1080-thx-ultra-200w-cLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Thank you all, for your inputs.
I exchanged the LSi 15's for a pair of RTi A7's.
It was by chance that I won the pair of LSi's. I'd not thought out the implications before I bid on them. Not a bit.
As it turned out, not only did I not know enough about the speakers, I did not even know enough about my own receiver. However, I'm glad because I've learned a bit now.
Quite frankly I do not think that LSi 15's are the right size for my apartment living room. And I've been enjoying the bookshelves (TSi 100) that I got for free with the receiver so much so that I could not imagine how the behemoths I had won would change it all. I do know that I want a set of towers, and I can put the TSi 100's to work as surrounds. But I guess I'm not ready for LSi's yet.
I was thinking in terms of getting the XPA 3, when I realized I'd have to get a new receiver first. I'm pretty sure, in fact I know, that the whole system would have become difficult to set up in my apartment. Not to mention the expense I was not prepared for. It would have been a case of buying the horse because I'd bought a horseshoe, and so on and so forth. -
Good move, glad you were able to do this exchange, I think this was a better approach than running out for a new AVR and amp. The TSi are not the "perfect" match for the RTi's but will be ok as surrounds, you should be happy as you will have a good sounding system. No need to rush into everything too fast.
Enjoy what you have, stick around here and you can formulate a plan to get what ever you want out of your system. Many here have done it this way, and many still are building up what they desire. -
Good move, welcome to the Club.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
outlaw makes some good amps
You most likely will want a bigger amp than the UPA 2. Since that is going for $324 shipped I would suggest something like this:
http://vintagehifipgh.com/index.php?main_page=product_info&cPath=6&products_id=35&zenid=9j968nd0g75v75r648s49khdc5
The Carver TFM 24 is 225 into 8 ohms and 350 into 4 ohms.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
thuffman03 wrote: »You most likely will want a bigger amp than the UPA 2. Since that is going for $324 shipped I would suggest something like this:
+1 Here. You definitely can't go wrong there. Highly Recommended.----Bill(BB3)Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Sonic Frontiers SFCD-1
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
2-Carver Silver 7-T's
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio SDA-SRS 1.2TL
PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
PolkAudio RTA-15TL
PolkAudio M3
3-Velodyne F-1500's
