Which 2 channel pre-amp under $600.00
Neale13
Neale13 Posts: 88
edited November 2009 in 2 Channel Audio
I need a 2 channel pre amp with at least 2 sets of pre outs for amps.any recomendations? New or used. Need remote control unit:confused::confused:
  • sucks2beme
    sucks2beme Posts: 5,703
    edited October 2009
    cruise on over to Audiogon and go nuts.
    90% of the responses will link you over there, anyway.
    Just do a search of your price range under preamps.
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    Adcom GFP-750
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    I like my Carver C5. It allows for two imputs to go to two different outputs and has a remote.
    http://vintagehifipgh.com/index.php?main_page=product_info&cPath=1&products_id=75&zenid=ghracrifvqd60nvk9iihopuq05
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    Dodd ELP--your arm is a great remote........The Dared tubed pre has a remote, almost as good, well, some think its as good. Or go crazy save your dough and get a Manley Shrimp, hey its what I do, overspend others money that is. :eek: come to think of it, I spend alot of my own as well on this stuff.
    RT1-Tubes Rule
  • madmax
    madmax Posts: 12,434
    edited October 2009
    Tons of stuff on Agon for that much. No doubt, buy used. :)
    madmax
    Vinyl, the final frontier...
    heiney9 Posts: 25,724
    edited October 2009
    The Dared is right up there with the Dodd w/the right tubes. It is remote but only has one set of outputs. Are you bi-amping each speaker is that why you need 2 sets of outputs?
  • Neale13
    Neale13 Posts: 88
    edited October 2009
    :confused:
    heiney9 wrote: »
    Im new here and this is what i have in mind. I have 2 outlaw mono blocks.they power my 2 fronts. Then I have 6 pair of in ceiling speakers wich i plan on powering with another 2 channel amp. with a 6 speaker selector for the ceiling speakers. I will need 4 amp pre-outs for the 4 amps ??does this sound right ? thanks
  • reeltrouble1
    edited October 2009
    seems you need 14 channels total of amplification then, are we talking stereo? multi? both??? do you want them all to play at once....different rooms???? you got some splainin to do........
    RT1
  • Neale13
    Neale13 Posts: 88
    edited October 2009
    RT1
    yes all play at once. using a speaker selector i will only need 1 , 2 channel amp to power my 6 ceiling speakers,right/ and my other 2 main speakers will remain powerd by my 2 mono blocks
  • Neale13
    Neale13 Posts: 88
    edited October 2009
    oh yeah stereo only,no home theater
  • miner
    miner Posts: 1,305
    edited October 2009
    A gently used Rotel RC-1070, RC-1090 or RC-1082 (this maybe a bit more). I have one int he For Sale section.
  • Krazyz1
    Krazyz1 Posts: 256
    e-bay did , still might had a ROTEL RTC-950AX. Ihave 1 and very pleased and DOES have 2 sets of out put.
  • danz1906
    danz1906 Posts: 5,144
    thsmith wrote: »
    Adcom GFP-750
    Agreed, really nice pre!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • phipiper10
    phipiper10 Posts: 961
    Anthem Pre 2L
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • LessisNevermore
    LessisNevermore Posts: 1,519
    danz1906 wrote: »
    Agreed, but I've seldom seen one under $600. (maybe one in rough condition?)
    edit: #700! woot.
