bike tubes
tobybad
Anyone ever used bike tubes for isolation? Someone on another site was talking about this the other day as a cheap tweek.
Post edited by tobybad on
Nope.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I was suggested to get some cork and a PC mouse "mat" and go from there, cheap and relatively easy to make
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
I have 6922 Bugle Boy tubes in my bike. They really improved handling._________________________________________________
What is this 'bike tube'-ing of which you speak?
? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
? Polk RTA 11TL's (FR and FL)
? Polk TSi200's (RR and RL)
? Polk CS10 (Center)
? Polk PSW-350
? Grado SR-60i Headphones
? Fii0 E5 headphone amp
? iPod touch (8 gig)
? iPod Classic (80 gig)
? Mac Mini (as media server)
? xbox 360 -
He's talking about the "tube" in the tire - a thin, smooth rubber tube. I've used them for a lot of little projects but never as isolation / insulation. Don't know if they'd really be thick / robust enough.If you will it, dude, it is no dream.
Hi,
When I had my TT next to the computer on a desk I used a 20" bike tube partially inflated as a damping pad. I placed the TT directly on the tube and it seemed to work well. I could knock on the desk and hear only a slight amount of sound into the TT. It was hard to keep level but once I situated the tube properly it stayed in place.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
OK, I'll come right out and say it. Bike tubes are a bad idea, period.
Look up sorbothane.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Sorbothane®, a one-of-a-kind visco-elastic polymer, was first introduced in 1982. Primary applications included the development of shock absorbing insoles for the athletic and orthopedic markets. Since its introduction Sorbothane® has been used in many varied energy absorbing product categories. Sorbothane Inc. engineers supplied the NASA design team with a unique Sorbothane® isolator to protect shuttle cameras during launch. The Liberty Bell was successfully moved using specially designed Sorbothane® isolators. When Wilson® Sporting Goods needed a superior shock absorber, for their new line of high-tech baseball gloves, they turned to Sorbothane®. Most recently, engineers have devised a series of colossal "ball-in-box" Sorbothane® dampers designed to dissipate wind energy in the new Air Force memorial.
You seem to know a lot about tubes, perhaps you can help. I've been bothered by what appears to be dust inside my tubes. I drilled a hole in the glass and cleaned the dust out along with that silver paint at the top. (They never seem do the entire inside, only the very top!) I get the vacuum back in with an AC vacuum pump, but the tire patches don't last long before melting off. Any ideas for something that might work?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I've read about using inner tubes for isolation and even got a tube to try it, but never went further than that. The only issue I can think of when using one tube would be tipping towards the heavy side/corner of the gear supported.
An article...
http://www.soundstage.com/weaver03.htm
An image...
thanks, SCompRacer for the link. Went to Walmart today and got some 12" tubes $3.50 each. Have not yet included the sandbags but so far BIG improvement in focus/clarity for $10.50. The money I saved can now go towards speaker cones and cables. GREAT cheap DIY tweek, always looking for more.
