bike tubes
tobybad
tobybad Posts: 16
edited October 2009 in DIY, Mods & Tweaks
Anyone ever used bike tubes for isolation? Someone on another site was talking about this the other day as a cheap tweek.
Post edited by tobybad on
    treitz3 Posts: 20,008
    edited October 2009
    Nope.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    I was suggested to get some cork and a PC mouse "mat" and go from there, cheap and relatively easy to make :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2009
    I have 6922 Bugle Boy tubes in my bike. They really improved handling.
    SOPA
  • everpress
    everpress Posts: 862
    edited October 2009
    What is this 'bike tube'-ing of which you speak?
    ? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
    ? Polk RTA 11TL's (FR and FL)
    ? Polk TSi200's (RR and RL)
    ? Polk CS10 (Center)
    ? Polk PSW-350
    ? Grado SR-60i Headphones
    ? Fii0 E5 headphone amp
    ? iPod touch (8 gig)
    ? iPod Classic (80 gig)
    ? Mac Mini (as media server)
    ? xbox 360
  • bobman1235
    bobman1235 Posts: 10,822
    edited October 2009
    He's talking about the "tube" in the tire - a thin, smooth rubber tube. I've used them for a lot of little projects but never as isolation / insulation. Don't know if they'd really be thick / robust enough.
  • bikerboy
    bikerboy Posts: 1,231
    edited October 2009
    Hi,
    When I had my TT next to the computer on a desk I used a 20" bike tube partially inflated as a damping pad. I placed the TT directly on the tube and it seemed to work well. I could knock on the desk and hear only a slight amount of sound into the TT. It was hard to keep level but once I situated the tube properly it stayed in place.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • zingo
    zingo Posts: 11,258
    edited October 2009
    If your creative enough to try it and it works, all the best to you.
    edited October 2009
    OK, I'll come right out and say it. Bike tubes are a bad idea, period.
    Look up sorbothane.
  • zingo
    zingo Posts: 11,258
    edited October 2009
    Sorbothane®, a one-of-a-kind visco-elastic polymer, was first introduced in 1982. Primary applications included the development of shock absorbing insoles for the athletic and orthopedic markets. Since its introduction Sorbothane® has been used in many varied energy absorbing product categories. Sorbothane Inc. engineers supplied the NASA design team with a unique Sorbothane® isolator to protect shuttle cameras during launch. The Liberty Bell was successfully moved using specially designed Sorbothane® isolators. When Wilson® Sporting Goods needed a superior shock absorber, for their new line of high-tech baseball gloves, they turned to Sorbothane®. Most recently, engineers have devised a series of colossal "ball-in-box" Sorbothane® dampers designed to dissipate wind energy in the new Air Force memorial.
    SCompRacer Posts: 9,112
    edited October 2009
    Ricardo wrote: »
    You seem to know a lot about tubes, perhaps you can help. I've been bothered by what appears to be dust inside my tubes. I drilled a hole in the glass and cleaned the dust out along with that silver paint at the top. (They never seem do the entire inside, only the very top!) I get the vacuum back in with an AC vacuum pump, but the tire patches don't last long before melting off. Any ideas for something that might work?
    edited October 2009
    I've read about using inner tubes for isolation and even got a tube to try it, but never went further than that. The only issue I can think of when using one tube would be tipping towards the heavy side/corner of the gear supported.
    An article...
    http://www.soundstage.com/weaver03.htm
    An image...
  • tobybad
    tobybad Posts: 16
    edited October 2009
    thanks, SCompRacer for the link. Went to Walmart today and got some 12" tubes $3.50 each. Have not yet included the sandbags but so far BIG improvement in focus/clarity for $10.50. The money I saved can now go towards speaker cones and cables. GREAT cheap DIY tweek, always looking for more.
