Is XPA-5 two channels strong enough power LSi25s?
chrisfromalbany
chrisfromalbany Posts: 41
edited October 2009 in Speakers
Basically I was powering my LSi25 my a old peavey CS 800 but didn't like the noise it made when running so ordered a XPA-5 to use as part of a 7.1 seup. I had though about bi-amping he LSi25s with Onkyo 806 but read some posting that bi-amping watted power didn't gain much. the XPA-5s is rated 300 Watts at 4 Ohms and I don't think the overstate there output. Thoughts?
Post edited by chrisfromalbany on
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    Welcome to the Club!
    The XPA-5 will do the job,also try Adcom.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2009
    Welcome Chris. The XPA will do just fine & you don't need to bother with biamping since the XPA has more than enough without the extra wires.
  • jimmydep
    jimmydep Posts: 1,305
    edited October 2009
    I agree with Cfrizz, I have my LSI's bi-amped with the XPA-5, I bearly notice a difference (very subtle in the low end)....Not worth the extra wire.
    Jimmy
  • chrisfromalbany
    edited October 2009
    thanks I was just wondering if more then 300 watts was need to drive these to there best.
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2009
    The more power the better they will sound.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • cfrizz
    edited October 2009
    LOL! The LSIs will take everything you throw at them & demand more! Wingnut had a full set of LSIs being driven with 200wpc, she then purchased a 300wpc amp & got even better sound!
    Many on here say that the LSIs continually improve as you hook them up to better gear.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited October 2009
    cfrizz wrote: »
    +1, the XPA-5 is a good place to start, it will do you just fine.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • chrisfromalbany
    edited October 2009
    -Jeff
    what setting or presetting do you use on your 806?
    Also I am guessing I should switch the phase setting on the LSi25 because I have an external Subwoofer (oAudio + Templest-X DIY)
    The question I am wondering is if I should change the crossover on LSi25s to maybe 60Hz so it gets alittle more warmer sounding and leave the other lower end parts to Subwoofer.
  • chrisfromalbany
    edited October 2009
    Question...
    Is it better to
    1) Run LSi25s with only XPA-5
    2) Run LSi25s bi-amped with XPA-5 for bottom and Onkyo 806 as top
    The reason I am asking is I can do either of these setup for free at the moment. But if you bi-amp XPA-5 only to the bottom how much of there 300 watts do you lose. Then with top half being Onkyo 806 push about 100 Watts per channel to the top section.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    IMHO i would try bi-amp with the xpa5, run one channel each from the xpa5 to the low's and high's. Doing it like this would still leave you one free channel and may give a more positive "separation" effect :)
    I'm not 100% but i think once you hook up to your pre-out's the main AVR speaker out's are disabled :confused: Don't hold me to that so maybe better to wait for someone with more knowledge to chime in ;)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • chrisfromalbany
    edited October 2009
    don't think that is the case.. I did run my Peavey CS800 and Onkyo 807 together and that worked.
