vaselin on driver surround
amiti
amiti Posts: 24
edited October 2009 in DIY, Mods & Tweaks
I am not sure this is the right section for such a weird question but here goes :
While searching for alternatives to fixing my own problem with torn surround of my RT3 driver I came across a cheap Polk 10 monitors. The owner said he acted on a dubious suggestion and put vaseline on two of the mid driver surrounds to revive the rubber. As a result the rubber expanded and loosened.
Are these drivers total loss now? Is it possible to fix this in anyway but replacing the surrounds/drivers?
Post edited by amiti on
    F1nut Posts: 51,893
    edited October 2009
    Total loss.
  • skrol
    skrol Posts: 3,456
    edited October 2009
    What model drivers are they? There are a few MW6502's on EB now.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • amiti
    amiti Posts: 24
    edited October 2009
    I don't know what drivers exactly those monitors use. I wanted to hear opinions here before I consider paying for the speakers. He asks about 80$ for them.
    Thanks ,Lasareath. I want to avoid patches by using liquid tape. When I get it in a few days I will see if it is strong/elastic enough. If not I will continue in the path of rubber cement/bicycle kit.
    Aren't there rubber surrounds kits for this size that would be suitable ?
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    Do you have a pic of them? It is kinda a loss unless you are in a remote area, and the tweeters are the peerless models. Are the surrounds torn? They are very supple by design.
    Ben
    Ben
    F1nut Posts: 51,893
    edited October 2009
    There are plenty on Monitor 10 speakers floating around, keep looking for a pair that actually work.
  • amiti
    amiti Posts: 24
    edited October 2009
    I was only thinking the price is low enough to make the deal worth while . I wasn't looking for a such large speakers to begin with :)
    Thanks.
  • amiti
    amiti Posts: 24
    edited October 2009
    Lasareath, I think skrol was refering to the monitor drivers...
    I can make a good use with an SRT then ;) though I don't think I will bother. I took a closer inspection of the second driver today and found it was deteriorating also. Maybe the high tempratures/humidity level here contribute to their quick wear out. I am only guessing.
