Aragon 8008ST 2 channel amp
hoosier21
Sorry for the bad picture of theis great amp. Selling to fund another audio toy. I have the original box but not the packing, and the power cord that I got with it when I bought it, I assume it is original, but not 100% sure. ASk me any questions.
Online manual.
http://www.klipsch.com/na-en/products/8008st-overview/
Specifications
Description: Two-channel solid-state power amplifier.
Rated power output: 200Wpc continuous into 8 ohms (23dBW), 400Wpc continuous into 4 ohms (23dBW).
Rated full-power bandwidth: 5Hz-20kHz.
S/N Ratio: >110dB, A-weighted.
THD: 0.04%, 5Hz-20kHz, at full power into 8 ohms.
Slew rate: >120V/µs.
Damping factor: >450, equivalent to an output impedance below 0.018 ohms. Input impedance: 22k ohms.
Input sensitivity: 1.68V for full output.
Power consumption: 1500W.
Dimensions: 19" W by 6.6" H by 14.6" D.
Weight: 70 lbs.
Retail Price: $1999
Audio Review site for owner reviews
http://www.audioreview.com/mfr/aragon/amplifiers/8008st/PRD_115555_1583crx.aspx
Asking 750.00 plus shipping, Paypal welcome.
Russ
Online manual.
Specifications
Weight: 70 lbs.
Retail Price: $1999
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
Links no good...
"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Great Amp-lots of power-Good luck with the Sale!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
That'll be a Great amp for a pair of LSi15's!
It would be, or for any other speaker I can think of.
Tank! GLWSNever kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
So, this is a dual-mono and NON-COMMON GROUND? This won't work for SDA's or can the negative terminals be strapped on this?
I don't know, I will checkDodd - Battery Preamp
measured 20 ohms across neg terminalsDodd - Battery Preamp
anonymouse wrote: »Is that symmetrical? i.e. is it the same reading if you reverse the probes? Sounds like it may be sharing the same secondaries, but has completely separate circuits from the rectifiers on.
yes 20 (19.9) either wayDodd - Battery Preamp
make me an offer folks, don't be shyDodd - Battery Preamp
Is that a built in cd rack in the top of it?
concealer404 wrote: »Is that a built in cd rack in the top of it?
exactly, multi functional unit here folks.Dodd - Battery Preamp
OK, you asked for an offer, how about $500.00?
Thanks, T. J., -
Thanks, T. J.,
How about we pretend you didn't say that."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
That is a nice amp...a friend of mine owns a similar one (not sure on the number) and he runs a set of Dali Ikon 6s with it...plenty of power.
And welcome to Club Polk T.J....stick around a bit and get the feel here before you make an offer, though..OK...
Thanks, T. J.,
I did ask for an offer, I will passDodd - Battery Preamp
I'm still a bit confused, this amp is considered a non common ground amp?
Polkie2009 wrote: »I'm still a bit confused, this amp is considered a non common ground amp?
If he measured 20 ohms between the left and right negative terminals then yes it is, but the negative terminals would need to be strapped together.Testing
Testing
Testing -
sold locally, thanks for lookingDodd - Battery Preamp
