Aragon 8008ST 2 channel amp
hoosier21
hoosier21 Posts: 4,418
edited November 2009 in For Sale (FS) Classifieds
Sorry for the bad picture of theis great amp. Selling to fund another audio toy. I have the original box but not the packing, and the power cord that I got with it when I bought it, I assume it is original, but not 100% sure. ASk me any questions.
Online manual.
http://www.klipsch.com/na-en/products/8008st-overview/
Specifications
Description: Two-channel solid-state power amplifier.
Rated power output: 200Wpc continuous into 8 ohms (23dBW), 400Wpc continuous into 4 ohms (23dBW).
Rated full-power bandwidth: 5Hz-20kHz.
S/N Ratio: >110dB, A-weighted.
THD: 0.04%, 5Hz-20kHz, at full power into 8 ohms.
Slew rate: >120V/µs.
Damping factor: >450, equivalent to an output impedance below 0.018 ohms. Input impedance: 22k ohms.
Input sensitivity: 1.68V for full output.
Power consumption: 1500W.
Dimensions: 19" W by 6.6" H by 14.6" D.
Weight: 70 lbs.
Retail Price: $1999
Audio Review site for owner reviews
http://www.audioreview.com/mfr/aragon/amplifiers/8008st/PRD_115555_1583crx.aspx
Asking 750.00 plus shipping, Paypal welcome.
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
  • xj4094dg
    xj4094dg Posts: 1,158
    edited October 2009
    Links no good...:confused:
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • hoosier21
    edited October 2009
    xj4094dg wrote: »
    fixed
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    Great Amp-lots of power-Good luck with the Sale!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • hoosier21
    edited October 2009
    Lasareath wrote: »
    That'll be a Great amp for a pair of LSi15's!
    It would be, or for any other speaker I can think of. ;)
  • Toxis
    Toxis Posts: 5,116
    edited October 2009
    Tank! GLWS
  • analog97
    analog97 Posts: 328
    edited October 2009
    So, this is a dual-mono and NON-COMMON GROUND? This won't work for SDA's or can the negative terminals be strapped on this?
  • hoosier21
    edited October 2009
    analog97 wrote: »
    I don't know, I will check
  • hoosier21
    edited October 2009
    measured 20 ohms across neg terminals
  • hoosier21
    edited October 2009
    anonymouse wrote: »
    Is that symmetrical? i.e. is it the same reading if you reverse the probes? Sounds like it may be sharing the same secondaries, but has completely separate circuits from the rectifiers on.
    yes 20 (19.9) either way
  • hoosier21
    edited October 2009
    make me an offer folks, don't be shy
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    Is that a built in cd rack in the top of it? :p
  • hoosier21
    edited October 2009
    exactly, multi functional unit here folks.
  • tjmarrone
    tjmarrone Posts: 1
    edited October 2009
    OK, you asked for an offer, how about $500.00?
    Thanks, T. J.,
  • sucks2beme
    sucks2beme Posts: 5,684
    edited October 2009
    tjmarrone wrote: »
    Thanks, T. J.,
    How about we pretend you didn't say that.
    edited October 2009
    That is a nice amp...a friend of mine owns a similar one (not sure on the number) and he runs a set of Dali Ikon 6s with it...plenty of power.
    And welcome to Club Polk T.J....stick around a bit and get the feel here before you make an offer, though..OK...
    cnh
  • hoosier21
    edited October 2009
    tjmarrone wrote: »
    Thanks, T. J.,
    I did ask for an offer, I will pass
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited October 2009
    I'm still a bit confused, this amp is considered a non common ground amp?
  • Systems
    Systems Posts: 14,873
    edited October 2009
    Polkie2009 wrote: »
    If he measured 20 ohms between the left and right negative terminals then yes it is, but the negative terminals would need to be strapped together.
    Testing
    Testing
    Testing
  • hoosier21
    sold locally, thanks for looking
