Trouble with bi-wiring, system "Overloads" when tweeter used
So far my success with bi-wiring is minimal. I have gotten some good sound, but if I go too far up with the volume, the receiver displays "OVERLOAD" and shuts down. At first I had the highs wired to the Front B connectors in the back, but after reading some about bi-wiring I put both the highs and lows in the Front A connectors.
After doing some troubleshooting, I found that if the Tweeters are disconnected the system no longer overloads. Why would this be?
Does anyone know the correct gauge of wire for wiring the tweeters separately? I am told my speakers are "Rt55 originals". They each have a tweeter, and 2 mid ranges. Or couldn't I just get some Bi-wire cable? I've seen it online but it can be pricey. I need about 6 foot of length max.
Can I take my existing Monster cable (not sure what gauge it is) and cut the ends off (the metal tips with plastic rubber around it) and divide the wire strands on one end into 4 ends? I saw these "bi-wire pants" on Ebay. Can I split the ends and make my own bi-wire this way?
Post edited by bigcarpileup on
Welcome!
    edited October 2009
    Did you remove the jumpers from your speakers?
    edited October 2009
    +1
    Very familiar with those speakers, and if you don't remove the jumper post (gold metal post between the speaker terminals) you will damage said-components. That being said, are you bi-wiring from a receiver or from 1 external amplifier? Almost always will you NOT hear any difference in SQ because power is all coming from the same power supply/amplifier section, thus you won't be receiving "more power" like you thought you would. Alot of people mistake this for bi-amping.
    If you are indeed running them off an AVR, might I suggest an external amplifier, your ears will thank you.
    P.S. If you are running just 1 amp for these speakers IE 2 channels from 1 amp or an AVR, try replacing the stock binding posts with some quality speaker wire.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    edited October 2009
    To keep it simple just do this:
    I noticed quite a difference when i did it :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
    edited October 2009
    This example is only showing a jumper to bi-wire is to use two seperate cables or one single with bass and treble leads. For more details audioquest published some paperwork explaining the application of bi-wire. Some will argue the merits of bi-wire but let your ears be the judge my advice is one pair of really good cables with a solid jumper like the ones offered by audioquest.
    edited October 2009
    ^^ I know what it is that i did, seeing as the OP is using an AVR to try this (bi-wiring) i suggested a quick/simple "mod" to improve his sound untill he had the proper equipment to do some bi-wiring :)
    Media Room 7.1
    HTPC
    edited October 2009
    Okay. I will try and update this as best I can.
    I am bi-wiring using a Pioneer Stereo Receiver VSX-605S. (see pic)
    I am bi-wiring using 2 separate wires for tweeters and the lows.
    Almost always will you NOT hear any difference in SQ because power is all coming from the same power supply/amplifier section, thus you won't be receiving "more power" like you thought you would. A lot of people mistake this for bi-amping.
    I don't want that much power, I'd rather have the sound quality. The sound was really good when I had the highs in the Front A connections and the lows in the Front B connections. Or at least it sounded really good to me. But when I turned it up even a quarter of the way, "OVERLOAD" blinked and it shut down.
    Even after putting both sets of wires (highs and lows) all in the Front A connections it still "OVERLOADS" and shuts down.
    I am unfamiliar with the term "AVR" !
    I am a bit of dunce with this compared to the rest of you and by "External Amplifier" do you mean a second Stereo Receiver? Or like the AMPS people used to put in their cars when I was a teenager??
    So you are saying by Bi-wiring with a single Stereo Receiver like mine is a waste of time and that I should just wire it up with the binding posts?
    So I should use a short length of wire as a jumper? I should get a solid jumper from audioquest? i just looked on the audioquest website. Could not find the jumpers...
    hmmm... the current state of the speakers. You know what... I had my Monster Cables attached to the the connectors for the tweeters at the top. The Monster Cables are not pictured...
    edited October 2009
    Well you understood everything I got at.
    Try powering your speakers WITHOUT BI-WIRING, but use a small piece of wire between the posts such as the picture posted up above and tell us if it still goes into overload.
    AVR means audio-video receiver...pretty much what you have.
    When I say external amplifier.....those amps you saw in cars is a good example. Except there are such amplifiers (in the shape of a receiver, rectangular) available for home use and used strictly to power a pair of speakers with more and clean current.
    -Freddy
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited October 2009
    I would be VERY CAREFUL wiring like in the picture. Having both +/- next to each other is very easy to get a short, which tends to be a bad thing.
    Seperate the two strands back by 1 foot, then attach both wires on the left side of the post and wrap the bare wire to the right around the post. This way when you tighten it will pull the wire in. Wrapping to the left will have a tendency to unwrap when tightening the post.
    edited October 2009
    BlueFox wrote: »
    After seeing the pic, Imma take a stab, and say a stray wire strand may have caused the shutdown.;)
    edited October 2009
    Is this an example of biwiring or a substitute for the solid jumpers that come with the speakers?
    Testing
    Testing
    Testing
    edited October 2009
    ken.paduch wrote: »
    Yep it is, although bi-wiring almost always shows no increase in sound quality. I would guess that the difference would come sooner if you replaced the jumper between binding posts with quality wire as opposed to bi-wiring. Just my .02
    -Freddy
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited October 2009
    I redid the wiring using wire instead of a jumper. Like the photo in post #4. Instead of wrapping the wire around, I put it through the hole that I didn't see the first time around. It's okay for now, but I have some work involved. I will update with a new photo as soon as I can.
    But with the jumper method, there was no OVERLOAD to speak of. I turned the volume a little more than half way up and had no errors.
    Can someone send me a link to one of these amps you would use for Bi-Amping?
    edited October 2009
    In order to use bi-amping, you would need 2 amplifiers.....or better yet a stereo amplifier with true monoblocks built in. A 2 channel amplifier will not be the same since all power comes from the same amp section and power supply.
    Does your AVR (receiver) have preamp outputs? That's where you'd connect an external amplifier to then utilize your AVR as a preamp. Please post any questions if I lost you :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited October 2009
    You should be looking elsewhere if you want to improve the quality of the sound.
    edited October 2009
    +1, this won't do much for you as far as SQ is concerned. As stated above in a few posts.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited October 2009
    x99
    Bi-wiring is a waste of time, IMO. Unless you're going to bi-AMP, don't bother.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    edited October 2009
    TNRabbit wrote: »
    x99
    Bi-wiring with an AVR is pointless IMO but if you have a quality AMP with multiple channel's i think it would give an audible benefit, probably increase the "separation" and enhance the quality of the frequencies :o By how much i don't know....
    Media Room 7.1
    HTPC
    edited October 2009
    try bringing 2 sets of speaker wire for each speaker both attached to the same channel at the amplifier and using the seperate posts at the speaker , i did it this way and definetly heard a big difference with the sound.
    nad t175 processor
    Sunfire TGA 7401 amp
    LSi15 front
    LSi center
    LSI 9 surround
    dual sunfire hrs 12 subs
    LG bd 390 blueray
    Sonos
    edited October 2009
    I do not believe I would call this " bi-wiring". This is what I would call a :confused:replacement of a metal jumper with a wire jumper.
    :confused:
    edited October 2009
    Who said that was bi-wiring? lol
    I simply said to keep it simple and just replace the metal jumper. I merely posted the pic to make it even simpler :o
    Media Room 7.1
    HTPC
Welcome!
Welcome!
