Elemental Designs a2-300
kevhed72
kevhed72 Posts: 5,146
Has anyone had any expereince with this sub for HT? Specifically, have you purchased one and found it not to be "enough" sub for your room. My room size is 17' x 21' approx with 8 ft ceilings...
Post edited by kevhed72 on
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    I have not heard this subwoofer, but SVS makes great subwoofer in the same
    price range.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    at 2856 cubic feet the 200w amp may be too small.
  • apphd
    apphd Posts: 1,514
    edited October 2009
    danz I guess that depends on what your definition of "range" is. The eD ships for $350, I know that "free shipping" is not free, but how ever you look at it final cost is $350. What does SVS have in that range?
    SVS does right now have a "B" stock PB12 NSD for $500 (saves you $70) something to consider.
    kevhed all that being said, I use an A2-300 in a room a little smaller than yours (2500 cft), and it does a very good job for HT. Its weakness would be 2 ch. but it does a respectable job with music for my tastes.
    Not sure what your budget is, but I would say contact them, (e-mail, phone, or they offer an on line contact with sales through their web site) give them your room info and see what they recommend. I have heard they give honest advice compared to the "got to move model x today", or selling what gives them the highest commission. I believe SVS and HSU also offer this honest advice on product selection if you contact them.
  • thsmith
    edited October 2009
    The nice thing about HSU is they rate their subs based upon room size.
  • jinjuku
    jinjuku Posts: 1,523
    edited October 2009
    I have put in 3 of these over the past couple of years. At $350 it's one of the best bang for the buck HT subs.
    I would also look at the BIC Acoustech PL-200. If I can use my experience with the H100 as an indicator you should be happy with the PL-200. I haven't heard it but just going off my experience with the other sub in the Acoustech line up it will probably do well. I am sure there are reviews out there for that sub.
  • jinjuku
    edited October 2009
    Do you have the ability to build your own speaker cabinet? That would be another option (DIY).
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    jinjuku wrote: »
    +1
    Much cheaper too.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • danz1906
    edited October 2009
    apphd wrote: »
    Wow, $350.00 is a great price- I stand corrected:p
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
