Bi-Amping, My Findings....
VR3
VR3 Posts: 29,399
Alright,
Today has started off basically as a day to screw around with speakers, so while I was in the mood....I decided to biamp *ONE* of my RTi70. The right one to be specific. So, I have the extra IXOS Mark gave me, I get it all wired up. Turn on the amp, man I'm pumped! I'm ready to hear an improvement...
So...I turn on a familiar track that I am used to...
I listen carefully....
zooming in on the highs of the RTi70 on the right, then the left....
No Difference......*maybe a tad sweeter...nothing worth plugging an amp up to...*
Zooming in on the mids, little to no improvement.....
I was like, well dang! Adding 2 amps to one speaker has to do something!!!
So...
I turned off my subwoofer, weak...so I set the crossover to 20hz (I know my sub can't hit that low, but it has a crossover setting that low)...
Well here we go! WOW! NOW THERE IS THE DIFFERENCE...
Although slight, it has much more.....*UH*....Poundage? lol
Overall, I found bi-amping not worth 200 dollars....so I will unwire the configuration and leave it be...
This is my opinion, for I hold no responsibility for shattered hearts, broken limbs, dumbfounded minds, or beyond this world mental illnesses this may cause you bi-ampers out there to read...
Anyways....this is what I found....oh well
Post edited by VR3 on
  • faster100
    faster100 Posts: 6,124
    edited September 2003
    don't feel bad sid, I had a Onkyo 504 amp with A & B outputs and i bi-amped my 70's and didn't really tell any difference either. people who do i guess just do, But i had 165 watts to each binding post and didn't notice anymore then maybe like you said, more power obviously, but not much else
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Tour2ma
    Tour2ma Posts: 10,177
    Interesting experiment doing one ch and not the other... very inventive lil bro...
    I think what you learned is neither your wire nor your amp is limiting your system performance at this time in your listening space. Another day, in another (larger) room and you might hear a diferent result.
    Like I say very inventive... wonder if you can "test" different wire this way????
    More later,
    Tour...
    Vox Copuli
  • wlrandall
    wlrandall Posts: 440
    Agreed, very innovative test method. Definitely noticed a difference with my 800s biamped. Not necessarily louder, definitely fuller and more headroom before clipping. Room is 18' x 19' x 8' with openings in the rear L/R walls.
  • HBombToo
    HBombToo Posts: 5,256
    Agreed Tour.
    and again Good job Sid
    HBomb
    ***WAREMTAE***
  • izafar
    izafar Posts: 819
    I have read somewhere that to really benfit from BiAmp you need to have external crossovers and you should have speakers on which you can disable internal crossover. I think the idea is to have an external crossover before the amp, so that the amp only works in a specific FR. This also allows an amp to have a better controll over the driver (as there would be no crossover in between). Has any one tried this sort of BiAmping?
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • Tour2ma
    You may have read that here. Was raised a while back.
    While the consensus was that it is the only way to truly unburdon an amp, it is difficult to do and can lead to many issues.
    May get my search on and dig up the old thread later.
    More later,
    Tour...
    Vox Copuli
