Solen Caps give away
NJPOLKER
NJPOLKER Posts: 3,474
edited October 2009 in DIY, Mods & Tweaks
I have some spare Solen Capacitors that need to find a good home. For a fellow member who is planning on doing an upgrade I will mail them to you at no charge. Since I have no need for them maybe someone else can put them to good use. They have been installed in a monitor 10 x-over but never used. You will not have an issue with the leads by the way. I also have two 2ohm Mills resistors that are new.
Two 35uF
Four 12uF
Two 2uF that were in my Anthem PRE2L They are well burned in but can't see where anyone could use them.
Next I am going to look through the spare x-overs I have sitting around. I've collected a lot of stuff since joining this forum.
Post edited by NJPOLKER on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    edited October 2009
    NJPOLKER wrote: »
    Two 35uF
    Four 12uF
    Would these work in a Monitor 10A with the peerless tweeters? If so I would like to take you up on your generous offer. PM sent.
    Thanks, Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • NJPOLKER
    edited October 2009
    Hey Mike,
    They should be a perfect match but you should double check the values of the existing capacitors. I was going to use these in my 10's with Peerless tweeters till a baseball bat took care of that project.
    Drew
  • michaeljhsda2
    edited October 2009
    NJPOLKER wrote: »
    Hey Mike,
    Drew
    Bummer about the baseball bat :( Here's a nudie of the xover.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • NJPOLKER
    edited October 2009
    Can you see any values printed on them? I can't
  • Systems
    Systems Posts: 14,873
    edited October 2009
    NJPOLKER wrote: »
    Generous giveaway,did you install them then decide to try something more "exotic"?
    Testing
    Testing
    Testing
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    I'd be interested in 2x 12uF for my SDA1C x-over redo. Nice little karma you've got going btw :D
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • michaeljhsda2
    edited October 2009
    NJPOLKER wrote: »
    I don't see any writing on them.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • NJPOLKER
    edited October 2009
    GV#27 wrote: »
    One of the speaker cabinets got hit by accident with a baseball bat. I was in the final stages of applying the final coats of poly when the accident happened. Drew Jr.'s baseball coach said he can hit bee's with a baseball bat he so good, well he can hit just about anything I guess. So I put the Monitor 10's in the closet for now.
  • NJPOLKER
    edited October 2009
    kawizx9r wrote: »
    That's funny you need a pair of 12uF's because when looking thru my spare x-overs I found a pair still soldered in the x-over. I'll de-solder them and send them out if you PM me your address.
  • NJPOLKER
    edited October 2009
    Thats all folks.
    For now anyway.
  • kawizx9r
    edited October 2009
    NJPOLKER wrote: »
    I'd appreciate that!
    No hurry at all of course. I've already compiled a list of the parts I need and the sites I'd be going through and this just saved me another $20 or so :D
    Still have to finish my subwoofer project.......one project at a time ;)
    -Freddy
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • michaeljhsda2
    edited October 2009
    Out with the old...in with the new. Thanks again Drew!!!
    SDA SRS 2.3TL's
    SDA 2B TL's
  • NJPOLKER
    edited October 2009
    Mike
    Your more than welcome. One thing though, you really should have replaced the resistors. You can buy them for about $3.00 each. You can still do them but it would have been really easy when you were doing the caps. Looks good and keep us informed on your initial impressions and then your thoughts after a few hundred hours.
    heiney9 Posts: 25,396
    edited October 2009
    NJPOLKER wrote: »
    Mike
    x 1000.
    The resistor is in the signal path and the Mills wire wound non-inductive really is a lot smoother and natural sounding. Plan to do those in the future. Otherwise looks outstanding!!!
  • michaeljhsda2
    edited October 2009
    I bench tested the old caps and resistors and they were all within spec! The speakers sounded great to begin but it's nice to know I won't have to think about the caps for a couple more decades.
    SDA SRS 2.3TL's
    SDA 2B TL's
