2.3tl /mw6510
dracoskeeper
dracoskeeper Posts: 142
edited October 2009 in Wanted (WTB) Classifieds
I need one of these for my brothers 2.3's, I was over working on his furnace and listening to his 2.3's and noticed some scratchy sounds coming from the left speaker. Shut it down and gently pushed in each driver and found the culprit, the lower sda driver sounds like it needs some oil!:(
Post edited by dracoskeeper on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited October 2009
    best suggestion would be e-bay or a new one from Polk CS but new ones don't match exactly
  • restanim
    restanim Posts: 227
    edited October 2009
    Why don't the new ones match? Is it sonically or cosmetically or both? To me, they should match exactly because you are buying from the same company that made them in the first place.
    Mike
    polkaudio
    Currently Own:
    RTA-11T Light Oak, Aug/2011 to present
    SDA-CRS+ Aug/2011 to present
    RTA-11T Black, Dec/2013 to present
    Previously Owned:
    SDA-SRS 2.3 May/1990 to June/1991
    SRS 1.2TL June/1991 to May/1995
    SDA-1C Aug/2005 to Dec/2011
    SRS 1.2TL Sept/2009 to Sept/2015
  • restanim
    restanim Posts: 227
    edited October 2009
    Thanks Lasareath,
    To me this is crap. I followed the links in your post above and Polk should have made the drivers look the same, at least put the notches in the rubber surround at the screw holes. I know now not to order a replacement MW from Polk. I would look in the used market. I will definitely be gentile on my current drivers.
    Mike
    polkaudio
    Currently Own:
    Previously Owned:
    F1nut Posts: 51,768
    edited October 2009
    Considering that the speakers are nearly 20 years old, you should be thankful that Polk is supporting them at all.
  • restanim
    restanim Posts: 227
    edited October 2009
    Oh alright...
    You make a good point.
    I accept Polks effort.
    Mike
    polkaudio
    Currently Own:
    Previously Owned:
  • Systems
    Systems Posts: 14,873
    edited October 2009
    I think I have 4-5 6510's?
    Testing
    Testing
    Testing
  • Pauly
    Pauly Posts: 4,519
    edited October 2009
    187CAM wrote: »
    If you have a spare left over i am looking for 1 6510.
    PM me and let me know
    Pauly
    Life without music would
