TV Shopping, been a LONG time
concealer404
concealer404 Posts: 7,440
edited September 2009 in Electronics
So we, my recently reunited girlfriend and i, just moved into an apartment. Upon initial inspection, the living room seemed pretty good sized.
Well... upon move-in, the couch dominates it, and I have maybe 8-10 feet to the wall.
The TV will have to be wall-mounted, so we're looking at an LCD or plasma. A projector MIGHT be a possibility, but probably not with the budget we're looking at.
I'd like to spend $500 or less, but am a little flexible for the right set. Yes, i know this is kindof low, but being that i'll need a bigger one in the next two years when i buy a house anyways, i don't want to go hog wild here.
I'd like at least a 37", and 1080P.
I do not have an AVR that will handle HDMI, will this be a problem? I want the video quality of HDMI, but will just be running sound through my AVR. This new stuff confuses me.
Post edited by concealer404 on
  • TouchOfEvil
    TouchOfEvil Posts: 967
    While i do not know what set you should get you could run a hdmi switcher to handle different components. I have one from monoprice HDX-401 and it does a real nice job.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • concealer404
    Ah.... right on.
    What i'm worried about is how will i handle the audio if i'm going to be running the HDMI signal to the TV, but can't to the AVR? Am i able to use the HDMI as a video signal only?
  • TouchOfEvil
    Ah.... right on.
    Yep, i use the switcher to handle hdmi to my set and run rca's to the avr.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • concealer404
    Perfect! Alright... that makes things easy.
    Thinking of picking up this, unless someone has a blatantly better suggestion for the same price range:
    http://www.frys.com/product/5911074?site=sr:SEARCH:MAIN_RSLT_PG
    I know it's nothing special, but like i said, i doubt it'll get more than 2 years of real use. I can't really use a rear projection tv, which sucks, because i know i could get a lot more for my money. :(
  • seeclear
    seeclear Posts: 1,244
    +1 I have the hdmi going to the screen and optical going from the satellite receiver to the HT receiver for the sound. Or rca's or digital coax. It somewhat depends as well what outputs you have on your cable box or satellite receiver or whatever.
    FWIW, I would not be too hung up on 1080 resolution on a screen that size. If you could save some scratch and get a nice 720p, I really don't think you could see any difference on a screen less than 50". I've got a 40" screen in the LV and 720p looks fantastic. Take a look at this link:
    http://carltonbale.com/2006/11/1080p-does-matter/
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • Conradicles
    Conradicles Posts: 6,339
    No need for a 1080 37" TV. Your eyes can't tell from a screen that small.
    Go with a better name brand than the one in the link and try 720 (although most "720" are actually 768P).
    Sharp and Samsung make nice TV's on the cheap in that size. Also, don't be afraid to buy a used one...the new TV's last a really long time for the most part.
  • Rodeo0530
    Rodeo0530 Posts: 797
    One thing that you may want to consider when looking at LCD or plasma is the amount of light that you'll have. LCD's are a lot better for high light rooms, whereas plasma's are better in darker environments. I have a 50" plasma in a medium lit room, but no direct sunlight, and it looks great. I love my TV and think it looks as good or better than anyone I visit, but it's only 720 and theirs are all 1080. I think someone on here said the they bought an Insignia for a price around where you are looking and they love theirs as well.
    edit: this is the link to the post for the Insignia plasma TV.
    http://www.polkaudio.com/forums/showthread.php?t=87777&highlight=randy+box
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
  • concealer404
    ^Thanks guys!
    This is a medium lit room, with the only immediate window is a sliding glass door to the patio. It has shades all across it that can be drawn as necessary. At any given point, i can make the inside of the place look like dusk, so that's no biggie. I've just been more drawn to the slight (or so i feel) advantage that plasma has in the area of color.
    I'll be about 8 feet from the tv, so 720p seems to be ok as far as everyone says, then. Alright, that opens up my options significantly, and may even be able to find something for cheaper.
    Won't 720p mess up blue-ray playback, though? Or will it "down"convert to 720p and i won't see the difference?
    I'll look around and find a few that i like and probably pick your brains again. :D
    Thanks!
  • Conradicles
    You will not see the difference on a small TV...trust me.
  • obieone
    obieone Posts: 5,077
    I have a 4 year old, 32" Westinghouse LCD. You won't see a bad picture. Save your money for the next upgrade.
    BB has a 32" 720P lcd for $400 in this weeks ad.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    You could always look at something like this, bigger and still in your price range, don't know anything about Dynex...
    http://www.bestbuy.com/site/olspage.jsp?skuId=9144295&st=9144295+&lp=1&type=product&cp=1&id=1218035133352
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    +1 on not being able to see the diff. between 1080p and 720p on a "smaller" screen. You will swear it is full hd and save a decent amount of cash.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • concealer404
    Seems to get decent reviews, though... so that's a good thing. Thanks! I'll run that by the significant other. :D
  • RandyBox
    RandyBox Posts: 125
    Rodeo0530 wrote: »
    Love it more everyday!
    Regards,
    Randy
  • dvran
    dvran Posts: 280
    Go 720p for anything less than 40", you won't see a difference. I would suggest to sticking with LG, Samsung, or Sony for an LCD. Go checkout HHgregg first, they actually deal on prices. If you go with 720p, you might be able to work in a free stand with the price. Don't go to Walmart or Target because vendors make specific garbage versions (Toshiba, Zenith, RCA) of their products for those stores.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • apphd
    apphd Posts: 1,514
    As others have said, stick to a 720P, the budget names that all seem to have one or two models that get great reviews for their price Westinghouse, Olevia, Haier, Vizio, LG, with Sharp and Samsung having some decent budget models as well. I think when you go with the low end products from the big name players your probably getting a set that rolled of the same line as the smaller/less know brands. The big names focus their resources on their upper tier products and buy their low end from the others and re badge them (my speculation). So do not discount some of these unknowns as they provide some of the best bang for the buck with entry level sets.
    Although with these I would favor going brick and mortor over internet sales just in case.
  • tryrrthg
    tryrrthg Posts: 1,896
    Keep an eye on techbargains.com and slickdeals.net
    here is one from techbargains that is a bit over your budget but worth a look
    Sharp AQUOS LC40E67U 40 inch LCD HDTV (1080p) $599.99 Free Shipping, Sep. 28 8 AM
    Best Buy has the Sharp AQUOS LC40E67U 40" LCD HDTV for $599.99 Free Shipping. Tax in most states.
    1920x1080 @ 1087p; 4 HDMI; HD tuner
    LINK
  • millerman 3732
    millerman 3732 Posts: 1,488
    I plan on picking this one up soon.
    42'' panny 720p plasma, $599
    http://www.bestbuy.com/site/olspage.jsp?skuId=9219213&type=product&id=1218061795104
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • Conradicles
    Perfect TV for that price. +1:cool:
  • tryrrthg
    dell had that tv or a similar one last week for under $500. saw it on slickdeals.
  • trunypa
    trunypa Posts: 1
    tryrrthg wrote: »
    I have the same idea with you. Great! Thanks for sharing. :cool::p
  • wutadumsn23
    reported
    HT Rig
    Blu-Ray- 80 GB PS3
