TV Shopping, been a LONG time
concealer404
So we, my recently reunited girlfriend and i, just moved into an apartment. Upon initial inspection, the living room seemed pretty good sized.
Well... upon move-in, the couch dominates it, and I have maybe 8-10 feet to the wall.
The TV will have to be wall-mounted, so we're looking at an LCD or plasma. A projector MIGHT be a possibility, but probably not with the budget we're looking at.
I'd like to spend $500 or less, but am a little flexible for the right set. Yes, i know this is kindof low, but being that i'll need a bigger one in the next two years when i buy a house anyways, i don't want to go hog wild here.
I'd like at least a 37", and 1080P.
I do not have an AVR that will handle HDMI, will this be a problem? I want the video quality of HDMI, but will just be running sound through my AVR. This new stuff confuses me.
Post edited by concealer404 on
While i do not know what set you should get you could run a hdmi switcher to handle different components. I have one from monoprice HDX-401 and it does a real nice job.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
Ah.... right on.
What i'm worried about is how will i handle the audio if i'm going to be running the HDMI signal to the TV, but can't to the AVR? Am i able to use the HDMI as a video signal only?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Ah.... right on.
Yep, i use the switcher to handle hdmi to my set and run rca's to the avr.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
TouchOfEvil wrote: »Yep, i use the switcher to handle hdmi to my set and run rca's to the avr.
Perfect! Alright... that makes things easy.
Thinking of picking up this, unless someone has a blatantly better suggestion for the same price range:
http://www.frys.com/product/5911074?site=sr:SEARCH:MAIN_RSLT_PG
I know it's nothing special, but like i said, i doubt it'll get more than 2 years of real use. I can't really use a rear projection tv, which sucks, because i know i could get a lot more for my money.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
+1 I have the hdmi going to the screen and optical going from the satellite receiver to the HT receiver for the sound. Or rca's or digital coax. It somewhat depends as well what outputs you have on your cable box or satellite receiver or whatever.
FWIW, I would not be too hung up on 1080 resolution on a screen that size. If you could save some scratch and get a nice 720p, I really don't think you could see any difference on a screen less than 50". I've got a 40" screen in the LV and 720p looks fantastic. Take a look at this link:
http://carltonbale.com/2006/11/1080p-does-matter/"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
No need for a 1080 37" TV. Your eyes can't tell from a screen that small.
Go with a better name brand than the one in the link and try 720 (although most "720" are actually 768P).
Sharp and Samsung make nice TV's on the cheap in that size. Also, don't be afraid to buy a used one...the new TV's last a really long time for the most part. -
One thing that you may want to consider when looking at LCD or plasma is the amount of light that you'll have. LCD's are a lot better for high light rooms, whereas plasma's are better in darker environments. I have a 50" plasma in a medium lit room, but no direct sunlight, and it looks great. I love my TV and think it looks as good or better than anyone I visit, but it's only 720 and theirs are all 1080. I think someone on here said the they bought an Insignia for a price around where you are looking and they love theirs as well.
edit: this is the link to the post for the Insignia plasma TV.
http://www.polkaudio.com/forums/showthread.php?t=87777&highlight=randy+box
Front - Polk Audio Monitor 70
Center - Polk Audio CS2
Rear - Polk Audio TSi 100
Sub - Klipsch rw-10d
AVR - Onkyo ht-rc180
Main Amp- Parasound HCA-2003
Surround Amp- Sonance Sonamp 260
Tuner- Parasound tdq-1600
Turntable- Pro-ject Debut III USB w/upgraded platter
IPod dock - Pure i20
TV - Panasonic Viera tc-p46g10
Sony Playstation 3(250GB)
Nintendo Wii
Power Conditioner- Panamax 5100
Not in use-
Polk Audio Monitor 60
Polk Audio PSW10
Parasound p/sp-1000 -
^Thanks guys!
This is a medium lit room, with the only immediate window is a sliding glass door to the patio. It has shades all across it that can be drawn as necessary. At any given point, i can make the inside of the place look like dusk, so that's no biggie. I've just been more drawn to the slight (or so i feel) advantage that plasma has in the area of color.
I'll be about 8 feet from the tv, so 720p seems to be ok as far as everyone says, then. Alright, that opens up my options significantly, and may even be able to find something for cheaper.
Won't 720p mess up blue-ray playback, though? Or will it "down"convert to 720p and i won't see the difference?
I'll look around and find a few that i like and probably pick your brains again.
Thanks!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »"down"convert to 720p and i won't see the difference?
You will not see the difference on a small TV...trust me. -
I have a 4 year old, 32" Westinghouse LCD. You won't see a bad picture. Save your money for the next upgrade.
BB has a 32" 720P lcd for $400 in this weeks ad.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
You could always look at something like this, bigger and still in your price range, don't know anything about Dynex...
http://www.bestbuy.com/site/olspage.jsp?skuId=9144295&st=9144295+&lp=1&type=product&cp=1&id=1218035133352 -
+1 on not being able to see the diff. between 1080p and 720p on a "smaller" screen. You will swear it is full hd and save a decent amount of cash.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
AsSiMiLaTeD wrote: »You could always look at something like this, bigger and still in your price range, don't know anything about Dynex...
Seems to get decent reviews, though... so that's a good thing. Thanks! I'll run that by the significant other.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Love it more everyday!
Regards,
Randy -
Go 720p for anything less than 40", you won't see a difference. I would suggest to sticking with LG, Samsung, or Sony for an LCD. Go checkout HHgregg first, they actually deal on prices. If you go with 720p, you might be able to work in a free stand with the price. Don't go to Walmart or Target because vendors make specific garbage versions (Toshiba, Zenith, RCA) of their products for those stores.~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
As others have said, stick to a 720P, the budget names that all seem to have one or two models that get great reviews for their price Westinghouse, Olevia, Haier, Vizio, LG, with Sharp and Samsung having some decent budget models as well. I think when you go with the low end products from the big name players your probably getting a set that rolled of the same line as the smaller/less know brands. The big names focus their resources on their upper tier products and buy their low end from the others and re badge them (my speculation). So do not discount some of these unknowns as they provide some of the best bang for the buck with entry level sets.
Although with these I would favor going brick and mortor over internet sales just in case. -
Keep an eye on techbargains.com and slickdeals.net
here is one from techbargains that is a bit over your budget but worth a look
Sharp AQUOS LC40E67U 40 inch LCD HDTV (1080p) $599.99 Free Shipping, Sep. 28 8 AM
Best Buy has the Sharp AQUOS LC40E67U 40" LCD HDTV for $599.99 Free Shipping. Tax in most states.
1920x1080 @ 1087p; 4 HDMI; HD tuner
LINKSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I plan on picking this one up soon.
42'' panny 720p plasma, $599
http://www.bestbuy.com/site/olspage.jsp?skuId=9219213&type=product&id=1218061795104Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
millerman 3732 wrote: »I plan on picking this one up soon.
Perfect TV for that price. +1:cool: -
dell had that tv or a similar one last week for under $500. saw it on slickdeals.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I have the same idea with you. Great! Thanks for sharing. :cool::p -
reportedHT Rig
Blu-Ray- 80 GB PS3
