Transcendent amp kit
madmax
madmax Posts: 12,434
edited May 2010 in DIY, Mods & Tweaks
I got it in the mail last night and I'm about ready to start! I hope I don't blow myself up... :eek:
http://www.transcendentsound.com/singleended.htm
madmax
Vinyl, the final frontier...
Post edited by madmax on
    treitz3 Posts: 20,049
    edited September 2009
    1.5 watts? :eek:
    Say it ain't so bro'! :D
  • Face
    Face Posts: 14,340
    Very cool, keep us updated.
  • Systems
    Systems Posts: 14,872
    Cool,do you have some big K horns to use with it?:D
    Single ended and OTL I assume there are some BIG coupling caps at the output.
    Testing
    Testing
    Testing
  • madmax
    I just finished most of the hardware steps, its about time to start soldering. I picked up some 4% WBT solder, man that stuff got expensive. $81 a roll! I probably should have just used the standard solder I have but who knows, maybe it will make a difference.
    Its 1.5 wpc or 4 wpc bridged. I may have to buy a second one. I'll be using it with my Avantgarde Duo's which are 104 db efficient. I tried the Duo's with the little 6w t-amp and it kicked butt, extremely loud. 1.5w may do it. :)
    madmax
  • dorokusai
    dorokusai Posts: 25,576
    Hey, if you're gonna build something nice like that Chuck...buy the good stuff.
  • danz1906
    danz1906 Posts: 5,144
    Good looking Amp!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • zingo
    zingo Posts: 11,258
    I've heard they make some good stuff and have always been interested in their products. Keep posting the updates and good luck with the build!
  • megasat16
    megasat16 Posts: 3,521
    madmax wrote: »
    madmax
    I am calling Homeland Security. You know I still got your address? :D
    Very Cool Project! Keep us posted!
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • dorokusai
    Hey Chuck, you know BlueMDpicker has built a few of those pieces...maybe drop him a line.
  • madmax
    I auditioned BlueMDpickers amps, I think he had two of the ones I'm building. His didn't go as loud as I would have liked but I think his speakers were about 96 db efficient. He did say something about them getting louder after putting a preamp in front of them.
    OK, time to start todays fun with the project!
    madmax
    mhardy6647 Posts: 35,157
    I am very curious to hear what you think about that little amp. It's an ingenious and (relatively) inexpensive way to sample OTL; certainly has a lot of potential if one has sufficiently senstive speakers (no dearth of those around here!).
    Best of luck; keep us posted!
  • madmax
    Just finished the power supply and the output board. Its starting to look like an amp. Now, its time for lunch!
    madmax
  • madmax
    edited October 2009
    Just got back from lunch :D and ready to start day 3 on this project. I have 10 hours in it so far, hopefully I can finish it up today.
    madmax
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2009
    Pictures.... or you bought it assembled.
    SOPA
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited October 2009
    There's a nice pair of Altec 16 ohm horns on the Bay.
  • madmax
    edited October 2009
    Ricardo wrote: »
    Ha ha, I knew there would be skeptics... Got the camera in hand. :D
    I'll check out those horns.
    madmax
  • Polkersince85
    edited October 2009
  • madmax
    edited October 2009
    I saw another horn/driver combo and decided to give it a try. Its the ones for $450.
    "Matching Altec 806A Drivers & H-811B Horns Valencia 846
    Up for grabs is a Pair of Matching Altec Lansing 806A Drivers with H-811B Horns. These drivers and horns are in excellent condition, work flawlessly and sound incredible!! They came out of a pair of Altec Valencia 846A Cabinets and are guaranteed to work or your money back. The diaphragms are original and are in excellent condition as well.
    FEATURES:
    16 Ohms
    Horn Dimensions: 18 3/4”W x 14” D x 8 5/8” H
    Distribution Pattern: 90° H x 40° V
    Cast Aluminum Horns
    Driver Numbers: 391917 & 391917"
  • madmax
    edited October 2009
    Darn, still not done. Still have the switch, LED and a little AC wiring to do. I guess I'll hit that tomorrow rather than take a chance on messing something up tonight. So far this kit has been a breeze but there are a lot of steps to do.
    madmax
  • madmax
    edited October 2009
    OK, I spent another 4 hours today and finished it up. I powered up and read 34V AC on each of the speaker outputs, no load was attached. I emailed them to find out if this is a problem. It could be normal with no load but I'm not sure. Cross your fingers.
    At least it didn't blow up or something. :)
    madmax
  • Systems
    edited October 2009
    There shouldn't be anything (other than a few mv of noise) on the output with no signal applied.
    Testing
    Testing
    Testing
  • megasat16
    edited October 2009
    madmax wrote: »
    How could this happen? Did you double check everything. I really think you should get a dummy load from parts express for testing DIY amps. Your speakers and your wallet will thank you! ;)
    edited October 2009
    madmax wrote: »
    madmax
    aiyeee! It's probably HUM (and plenty of it); sounds like the AC P/S is going straight through to the outputs. That would cook your speakers; 34 RMS V AC (if that's an RMS reading) would be 144 watts continuous into 8 ohms.
    Even if your ACV reading is peak to peak; 34V peak to peak is 12 V RMS which would be 18 watts continuous into 8 ohms. Still bad for speakers.
    fun formulas for electronics:
    E = I*R (Ohm's Law)
    P = I^2*R = E*I
    E = voltage (V)
    I = current (A)
    R = resistance (Ohms)
    P = power (W)
    V(rms) = V(peak to peak)/(2*SQRT(2))
    You don't somehow have AC going to ground, do you?
    Yes, you should have a dummy load; PartsExpress sells nice ones, or you can just get a pair of noninductive power resistors (5 or 10W for an amp like that is OK) of roughly 8 ohms (5 or 10 is close enough!) for testing.
    I don't s'pose you have a scope or a frequency counter to look at that AC signal, do you? I am guessing its 60 Hz, but mebbie not...
    Well, I guess, on the bright side, you dont' have DC on the outputs?!
    EDIT: Is that 34 VAC with respect to ground? Where do you have the other probe connected (the "-" speaker connection, or the chassis)?
  • zingo
    zingo Posts: 11,258
    edited October 2009
    Agree on the load. I just use about 5w of resistors soldered together and heat-shrinked in an 8ohm load and it provides plenty of help when testing amps.
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    How is it coming madmax ?
    Would this amp drive a pair of SDA-1Cs ?
    I am looking at a couple of kits that are rated between 40-60wpc.
    edited October 2009
    zingo wrote: »
    Y'know... it dawned on me that,for all I know, an unloaded OTL amp may do weird and wonderful things (such as powerful HF oscillation?). I just don't know...
    I.e., testing with the outputs loaded may sho'nuff be preferred for OTLs just as it is for transformer-coupled amps.
    thsmith wrote: »
    umm... the titular amp in the case of this thread is 1.5 watts per channel.
    There are 40-60 wpc OTL amps, but they're a bit pricey (and you can heat your listening room with 'em).
    These little guys, for instance:
    http://www.atma-sphere.com/products/index.html
  • Face
    Face Posts: 14,340
    edited October 2009
    Those are ugly as sin.
    edited October 2009
    Face wrote: »
    hmm -- I'd describe them as purposeful looking. They remind me of locomotives, somehow.
    Actually, what they really remind me of is an ancient piece of laboratory instrumentation called a Klett colorimeter. I suspect I am the only person here who knows what a Klett is, and I'd probably bet money that I am the only one who's actually used a Klett...
    heck, looks like they still make 'em...
  • analog97
    analog97 Posts: 328
    edited October 2009
    Ain't that thing a device to measure turbidity? Pretty sure I used something like that in an old microbiology class.
    edited October 2009
    analog97 wrote: »
    yup, exactly...
