Transcendent amp kit
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2009
    This 34vac could it be because it's single ended amp. A cap to the output giving you voltage if it's not loaded, behaps you could add a load of some kind to test. Now nothing you wish too use in the future, just a test speaker or resistor 8ohm 5w.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • madmax
    madmax Posts: 12,434
    edited October 2009
    Bruce from transcendent answered my question about the voltage, it shouldn't be there. He said he can only think a wiring mistake was made. Thats easy, I can just follow through the manual again to check the wiring. There are a lot of connections for sure and one geezing moment could cause a mistake. I'm just happy I had the foresight to test a few things before hooking up to other equipment. The manual assumes everything is done correctly and just tells you to hook it up. I was afraid to try a load because if something is miswired a load could pull a lot of current and possibly stress or fry some of the components.
    madmax
    Vinyl, the final frontier...
  • strider
    strider Posts: 2,568
    edited October 2009
    Have you had any luck, 'max?
    Wristwatch--->Crisco
  • madmax
    edited October 2009
    strider wrote: »
    I haven't had time to get back to it. I'm having a new roof put on the house plus having it painted at the same time. Lots of things going on this week.
  • madmax
    edited May 2010
    So I'm at work looking for some old schematics and I open up one of the cabinets I never use and there it is! A tube amp! 7 months ago I put it together and had a problem with voltage on the outputs. I put it away and totally forgot about it with everything else that was going on at the time. Well, I just ran through the assembly guide and found a wire was missing. Once I install it I hope the thing works properly. Is anyone else so scatterbrained as to forget something like this? I must be loosing it. :)
    madmax
  • madmax
    edited May 2010
    She powered up nicely, measures good on a scope, no dangerous external voltages and is showing no signs of any problem! I'll let her run for a few hours then hook up to some cheap speakers. Right now I have 10 ohm resistors as the load. Oh man what a beauty!
    madmax
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited May 2010
    madmax wrote: »
    I auditioned BlueMDpickers amps, I think he had two of the ones I'm building.
    Yep, I had two of them bridged mono driving the Cain & Cain Abbeys for awhile. They're very transparent sounding.
    And, yes, you're losing it. ;)
  • madmax
    edited May 2010
    I can't wait to hear it on the horns but given that its a kit I think I will abuse some other speakers first until I feel more comfortable with it. It needs to break in anyway. Well, I got it boxed up and am on my way home. So much for the work I was going to do today, guess I'll be here tomorrow... :D
  • madmax
    edited May 2010
    Let me proudly present: The Transcendent amp kit!
    Here is a box of parts needed for high quality sound.
    1.jpg 550.1K
    2.jpg 542K
  • madmax
    edited May 2010
    First pic is in almost finished form, still a few wires to attach. The second pic is where I tested it out in on some super low efficient speakers. I was able to power it up and play at full volume all evening without having to worry about the speakers or a lot of noise.
    3.jpg 551.7K
    4.jpg 506.8K
  • madmax
    edited May 2010
    And here it is all together!
    5.jpg 516.4K
  • madmax
    edited May 2010
    Review of the kit:
    I wanted one of these amps really badly but they come in kit form and I really don't have a lot of time for this type of activity. Besides that I'm an electrical engineer and see plenty of of this type of work all day every day, not something I like to do as a hobby. With that said I went ahead and ordered it anyway. I put a few full days into building it and found it an easy kit to put together. You need to know almost nothing to do it correctly. The manual is full of all the pics you need as well as drawings and easily worded paragraphs. Pretty much if you can look at pictures you can build this easilly. If you can see and can turn on a soldering iron it is a plus.
    I put it all together and measured a few voltages to make sure the unit was safe to touch and safe to connect to a preamp and a pair of speakers. No voltage was on the case, or input lines but there were 30 some volts on the speaker outputs. I sure was glad I decided to check before melting my speakers! I had a wire out of place. It was easy to look through the pics in the manual and find it right away.
    After getting it home I first connected to my upstairs rig. It uses a laptop as a source and feeds signal into a Music Hall USB DAC. The speakers are some very inefficient Diahlquist DQ-10's. I played full volume to them all evening just to test the amp and burn it in. The DQ-10s need a lot of power, 200+ watts and this amp only delivers 1 watt or so. They were not loud at all. I listened to it for awhile anyway and was quite surprised that even though I had very little volume I had the sense that the amplifier was taking control over them. The bass had authority and the highs were sparkling. The midrange seemed a little in the background. Anyway, enough of that, lets get to where I hooked them up to the 104DB sensitive horns instead of the 86DB DQ-10's.
    I disconnected the Manley 100w tetrode mode mono blocks from my main system and set this little 2 watt monster of sound in their place. I powered it up and dropped the needle in the groove. As I brought the volume up I noticed at about 12:00 on the knob was a pretty good volume for quiet type music. This is the setting where I normally play fairly loud music. Getting a little anxious that maybe this was going to be the loudness limit I put on some harder material and took the volume up to about 3:00. It was quite loud but not stadium loud like the Manleys. It then went to full throttle with no complaints from the amp or speakers. At this point it was too loud so I turned it back down. That was enough of a workout for one day so I shut it down.
    This morning I listened to various music and found the amp quite to my liking. Its strong points are a very authoritive quick bass, speedy sounding toe tapping qualities and the ability to play very complex music and allow different textures to dance around the room. The soundstage is exceptionally stable and often times a group of sounds get together and lead to quite an experience. I got goosebumps a few times and marveled at the many sounds I heard. The weak points are power related. With the horns a few watts are as good as a few hundred watts but most ordinary speakers wouldn't be loud enough for many of us. I guess a speaker efficiency of 96DB or greater is most reasonable for this type of amp.
    Wow, what an experience this amp provides!
    madmax
  • BlueMDPicker
    edited May 2010
    madmax wrote: »
    You did an excellent job on the amp, Chuck. I'm glad you like it. I liked the pair I had a lot.
  • madmax
    edited May 2010
    After another full evening of listening I'm beyond pointing out the differences between this amplifier and the ones I was using. Its easy to say this is better and that is worse but you have to get over that to really hear whats being presented. After all some aspects are better, some worse.
    I'm hearing some really incredible detail, solid bass and smooth highs. The glorious midrange is not something I can claim here. It shows up here and there, actually quite a bit of the time, but is not the biggest player in the overall presentation. When it shows up it is glorious, when it doesn't it doesn't. Maybe this shows that some amps have more color to them than others or maybe it says that midrange glory is not always there, I'm not sure. The way this amp puts all the different textures of complex sounds together is absolutely amazing! These textures and the bass are the true strong points of this amp. If I had it to do over again I would easily buy one of these again. However, my next amp will most likely be a 300B or 45 just so I can try more different things. This one isn't going anywhere soon. ;)
    madmax
    Edit: Oh yeah, it takes 230 watts from the wall plug to make 2 watts at the output. Amazing little heater here!
  • Face
    Face Posts: 14,340
    edited May 2010
    If you're looking for a SET, you should check this out: http://www.ayonaudio.com/products/amplifier/integrated-amplifier/crossfire.html
    I heard one recently and it's a wonderful sounding unit.
  • zingo
    zingo Posts: 11,258
    edited May 2010
  • madmax
    edited May 2010
    I've been thinking of the bottlehead 300B monoblocks. Then I look at the price and think for more $$ I can get some used Manley 300B mono's and not have to build them.
  • madmax
    edited May 2010
    Thats interesting. Good reviews too. I wish I could try a few different ones and pick the one I like. :)
