Half Price Power Cords
inspiredsports
inspiredsports Posts: 5,502
I just received some Mobile Fidelity Inner Sleeves to protect my LP's from MusicDirect.com and they included their latest print catalog.
I'm sure this is old news but . . .
. . . of special interest to me (as it is my new addiction :)) was their HALF-OFF SALE on Five foot 15 & 20 Amp Shunyata Diamondback Platinum Power Cords.
I have one on order and will be probably end up selling my 6' Signal Cable MagicPower after I compare the two when it arrives.
Music Direct is also offering a 100% trade-up credit for 3 years if you buy a higher grade Shunyata, and they offer a 100% money back guarantee if you don't like the cable when it arrives.
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
    Toolfan66 Posts: 18,053
    edited September 2009
    Can I be on the list for the signal cable if you sell it?
    Thanks,
    Larry.
  • vc69
    vc69 Posts: 2,500
    Why do you need to protect your LP's from MusicDirect.com?
    :p
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • inspiredsports
    Thanks,
    Larry.
    Absolutely. I'll PM you before listing. It's a great cable, but will become redundant if I like the Shunyata.
    Greg
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    vc69 wrote: »
    :p
    Yeah, I thought that sentence looked a little odd after I wrote it :)
    In my opinion, these are the best LP condoms you can buy and Music Direct currently has the best price: http://www.musicdirect.com/product/73913 :D
    NAD SS rigs w/mods
    GIK panels
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I like the Shunyata power cords, have fun.
    RT1
  • danz1906
    danz1906 Posts: 5,144
    Let me know how you like the Diamondback, Im also thinking about
    ordering one.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • inspiredsports
    edited October 2009
    I've had my first in play and powered up for about 120 hours (15A 5' Shunyata Diamondback Platinum).
    I used it to replace a 6' Signal Cable MagicPower from APC H10 to Little Pinkie Power Supply for a Musical Fidelity X-10v3 Tube Buffer between CD player and pre-amp.
    The sound improvement is subtle, but noticeable across the entire spectrum. Specifically, the bass is a bit more powerful (but certainly not overpowering) and the trebles are clearer.
    NOTE: these are very stout, stiff cables.
    As a side note, when it arrived, there was as code "SUM-10" postcard for a 10% off discount. I ordered another last night for $112.50 + $6.00 shipping (the first was $125.00 + $6.00 without the 10% off).
    I don't know if you could simply type this code in again or not, but it is worth a try for an additional 10% off.
    They also offer the 20A version for about $12 more which is tempting, but I'll bet it is incredibly hard to bend as the 15A is stiff as noted above.
    NAD SS rigs w/mods
    GIK panels
